Mustang5l5's Progress Thread - Archived Progress thread '08-'20.
I used to be on the Corral constantly. I never go there any more and it is 100% because of that dick. It only takes 1 to ruin a site. I can't believe the site owners don't see how he hurts what they care about....their revenue.
Doesn’t a corporate entity now own them? I doubt they care about the site. I give it a few years before it’s dead.
the latest porting threads on there are a perfect example of how wild it gets with no oversight
The (edit “fumes”) from zinc in weld through primer and galvanized metals should not be breathed in while welding. Adequate ventilation without blowing sway the shielding gas is required if you do not want to feel sick from breathing in the fumes.
The metal itself should not be breathed in either, but that’s not usually a problem on this planet’s temp ranges. Oops!
So now you have an extra intake. I could use an explorer upper and lower intake.
What's your experience with the weld through primer? I recall Dave saying he didn't care for it and it always gave him problems.
Does it require more heat than just the bare metal?
  • Useful
Reactions: General karthief
Yeah, it’s nasty stuff. I get a good breeze with the garage door open and back door open, but I rigged a fan above the work area to blow the fumes out and would work quick while holding my breath and then back away til the fumes clear.
I won’t be using any more of this stuff. I got better welds on bare steel to steel welds
Wasn't aware that was zinc weld through. Same thing with galvanized metal, too
Welding: if you aren't burning or blinding yourself, have some fumes instead.
Has anyone here tried the UPOL weld through primer?
This guy on youtube is building a Camaro and I've been watching every vid. He's very meticulous in what he uses, even found new sheet metal showing up with rust in between some of the sandwiched panels. Lots of episodes to go through, and he's not the best at giving a vid description but I'm learning a ton (even if it's a bow tie):
View: https://www.youtube.com/watch?v=dHSEpq-Hitg
This is what we use at work, it's better than most, but I still prefer bare metal to get a better weld
Reactions: JustinL
Also, I put this together for $50.
seller sold it as parts only because the faceplate was busted and a tape was stuck inside. Got it for $25. Found an NOS faceplate for $20. Got the tape out, tested it and it works.
into the pile it goes. I
So, planning the hydroboost setup with the ATS front and Taurus 43mm calipers.
This is a hydroboost issue, so don't correlate this to vacuum setups.
The 2004 Cobra hydroboost uses a 1 1/16" bore MC. When installing the ATS and 43mm rears, you are increasing the surface area of all the pistons being used. Normally they requires an MC upside in bore diameter. Except there isn't one with hydroboost.
Except there is now.
That's an expensive ass master cylinder. But, it would be technically "right" for the brake setup. Why are cars such money pits?
We will try the oem hydroboost MC first
Reactions: JustinL
Why does your driver’s front tire look slightly offset to the rear? Gotta be a phone camera trick, right?
BTW, I need to update you on the answer to this.
That's because apparently it was. When I was trying to install my lower K-member brace, in talking with MM and taking measurements, we discovered that my k-member was in fact bent. At some point in the car's life, the driver's wheel either hit something hard, or a curb, bending the rear of the k-member inward. The rear k-member pad was tweaked slightly, but I was able to fix that by bolting a 2x4 onto it and straightening it out. The MM k-member now bolts up fine.
But, it appears my k-member was bent on the driver's side putting the driver's side wheel slightly back in the wheel well. Good catch from back in the day.
Reactions: bird_dog0347
Would you recommend doing the SN frame rail to others down the road, or do you think the Fox one could be modified to provide proper drainage while being an easier install?
i think the Fox one is spot Welded in a more complex way meaning it would be painful to try and dissect it. I believe it can be done. But SN cars do rust out as well, so not sure it’s worth it.
if someone didn’t have a donor at all, id day go out and find the same year span fox panel. 79-86, 87-89 and 90-93 and use that as your splice panel. Just ensure it’s a rust free donor and spray tons of frame coating inside.
the SN frane is probsbly easier to locate right now, but extra work to relocate the holes. Also, I have no idea when ford made the frame rail simpler internally. Could be 94, 96 or 99
