Progress Thread 43 years later
I was cleaning the garage and found the cut up old motor mounts. @LILCBRA you can add these numbers to your list.
Reactions: LILCBRA
How are they mounted?
If you are back at the car, could you make a pic for me?
I just took the stock rails off the new seats and put my rails from the cobra on them. It's a tight fit but they work. I also had to remove the cover on the seat coil spring (helps assist the tilt of the seat back) to get them to fit. They're a little wider than the stock seats.
NICE!! I'll bet your ecstatic about that!! :nice:
Yes. It was about a 45 mile ride. I was so nervous that it would overheat or something. I could barely sleep the night before. My daughter gave me a ride out there and followed me back in case something happened. But, there was only 1 small leak in the brake lines. I'll try to get that fixed today.
Reactions: LILCBRA
