No notes, they usually ask in person. They all get the same answer though.....
ReAlLy?Lol
Not as guilty as it looks
What else will we find
don't lie to us - we're on to you!!
No real updates on the Cobra, but I did rummage through the extra Holley parts I have stashed. I have all of these main bodies and probably enough other parts to put at least 2 more together. I ordered a rebuild kit for a 4160 to put one together, I think I'm going to go with the 1850-3 body. So I'll probably mess with the 650 this weekend as well as the gaskets that need replaced, then rebuild the 600 vacuum secondary and mess with that later.
This post is more for my reference so I don't have to search for this stuff later. This is the Holley PDF document for their main body part numbers and corresponding parts for a complete, off the shelf carburetor.
As far as this document goes, the 1850-3 and the 1850-2 are both 600s. They both get number 66 primary jets and have side hung bowls and both have 134-9 metering plates.
The 3910 is a 780 double pumper with 71 and 76 jets with center hung bowls.
The 3310-2 is a 750 vacuum secondary with number 72 primary jets and center hung bowls. It has the 134-21 metering plate.
And the 4749-3 isn't listed but appears to be a 600 vacuum secondary destined for MOPAR engines from what I could find through Google. Apparently these are side hung bowls as well, but I have no idea about the rest of it.
Edit: Pics are for reference if I decide to swap the metering blocks to get rid of the plates and use actual jets on the secondary side.
it's yours for shipping
Eldelbrock performer 289 and its so old school its got the rear water passage still.
The RPM one was too tall to fit under hood, don’t know if this one will.
Will have to dig thur the carb pile to see what we can make work.
Of course it runs great the way it is...
Good is the biggest enemy of betterOf course it runs good the way it is.
I have a Eldelbrock RPM and this one, and as far as I can tell - I’ll have to cut a hole in the hood for ether.
