I don’t over-fuel the tank and never had a hard time re-fueling. The charcoal canister is soaked because no vapors are withdrawn from it and all I smell from the two venting ports is raw fuel instead of filtered air thru the charcoal pellets.If your canister is soaked in fuel your over filling the tank or you have a constant strong vacuum on it sucking fuel from a valve stuck open. Once there soaked its replacement time. Has the car ever been hard to fill with an auto shut off pump and you having to hold the gas Pump handle so it doesnt trigger and shut off early?
Haven't looked at a fox body canister in years or think I ever opened one up, but most of them that vent to atmosphere will be a one way valve or another selonid controlling the vent. We got them all the time working when I was in dealerships, mostly because once it's jacked they can't fill thier tanks with out the auto trigger nozzle shutting off from pressure build up, either plugged with fuel, or failed valves. Your going to need someone with a bin dump for the ecu to see programming for the purge on fox body stuff. Those system are way dumber then modern day obd2 so most people ignored or bypassed the systems by plugging lines or removing it all together. I only run them to deal with fumes and use newer model ones mounted by the tank.
Like I said during my test no ground signal was sent by the ECU AND I know the wire is good from the purge valve to the ECU 60 pin connector.
Believe it or not I opened and reactivated the charcoal pellets and sealed it back no more fuel smell at the venting ports, but I don’t want to install it until I see the purge solenoid valve opening and closing normally.
Here is my freshly rebuilt charcoal canister
