- Jun 14, 2007
- 513
- 284
- 93
So I'm in the process of replacing a lot of stuff during the winter months on our 90 7 up convertible. The whole intake manifold is off the car right now.
Ever since I ditched the bbk 70mm throttle body I've dealt with coolant leaking between the stock EGR spacer and throttle body. The parts I bought were used. I'm assuming something isn't square. These manifold studs are trick flow and I put these on less than 2 years ago. Assuming it's not normal for them to be rusty? Maybe put anti seize on them?
Either way, I'm seriously thinking about buying a accufab 65mm throttle body and a pro m MAF sensor. But seems like a waste on a otherwise stock car.
And I don't feel like ditching the EGR....
Thoughts?
Edit: you can kinda see some coolant on the outside of throttle body by gasket.
Also my big question is, can I run a stock 94-95 mustang 5.0 MAF sensor if I install a 65mm throttle body? I read that they are 70mm? I can't find the bracket anywhere though to mount to the stock air filter box.
Thoughts?
