- Jul 31, 2017
- 284
- 89
- 48
My new base model vortech v3 supercharger kit should be here by the end of the month at 5-6psi I had planned to go with a 3 staged plan.
Stage 1 was upgraded pump to a walboro 255 and install the kit as-is with the FMU.
Stage 2 was upgraded injectors, upgraded maf, install AFR gauge, and ditch the fmu.
Stage 3 was terminator x, sensors, adjustable fpr, no maf, and a smaller pulley.
Target of 400hp at wheels or crank, no more than 10lbs boost max.
I got a good deal on 30lb injectors and a matching maf earlier than expected.
Question is can I make this a 2 stage plan now and just not use the fmu and install the new injectors and maf with the kit? Will the stock computer be fine with 30lb'ers and a maf and just 5-6lbs boost? I will not yet have a AFR monitor on the car, this is why I'm concerned.
