Resolved Vortech hitting hood
92 LX UPR k member 8.2 deck motor with s trim. Car was running driving no problem. This winter pulled motor to paint engine compartment and change pan gasket. I noticed the motor mounts were smoked and ordered new ones. Car all back together, looks amazing runs perfect. Went to put the hood back on and no go. The hood actually hits the case…….not the clock able outlet. Order engery suspension motor mounts thinking the summit/pioneer brand mounts were wrong and same issue. I do not want to go to the solid/drop mounts.
Anyone have any ideas? I’m stumped. Been into foxbodys since 93 and not my first rodeo.
I am pretty sure that the urethane motor mounts will position the motor higher than the stock rubber mounts. Years ago Ford had two different motor mount for these cars, one was the standard one which the urethane motor mounts are patterned after and the other was for the convertible cars which lowered the motor about 1/2" or more. Later on Ford only had the convertible mounts and that is what you buy in the parts stores.
The 351W in my T-Bird sat too low in the car when I swapped it from a 302W. Canton road race pan was contacting the rack and pinion. I installed the urethan motor mounts and problem solved. Good thing it has a 3" cowl hood.
Reactions: SeaCorey
I have the newer style vert mounts, and still sitting way too high. Compared old pics from before and the blower pulley nut was right behind the radiator hose. Now it’s considerably higher. Wondering if I need OE mounts as I’m seeing lots of people say the parts store ones are junk
Just curious as to how you lifted the engine to get the new mounts in? I have to change mine but i don't have a hoist/top of engine lift. With my oil pan gasket already looking like dog:poo: i'm hesitant to lift it with a jack from the pan and 'squish' the gasket even more. I've seen people (KAZLCustoms?) lift from the balancer in one of his videos but also am unsure about doing that.
If you raise the trans will the front of the engine dip down? Just thinking if your new engine mounts are taller and you trans mount is low it might have increased the angle it's sitting at.
https://www.harborfreight.com/1000-...Kx_PjwtSBuM6eWqXjTDlZqF4EnJAqvjkaAodnEALw_wcB
To my knowledge, [all] of the modern captured mounts are taller than the OEM non-captured mounts.
Although I have not tested them all, the urethane mounts are taller still.
My only recommendation aside from slotting brackets :puke: would be to compare your new mounts to to these:
To see if the rubber variety will give you the wiggle room that you need.
The other, other option would to swap to a completely different mount. Maybe tubular with the spherical bushings (more ass pain).
Hmm, looks like it should fit. But I was reading a review on Summit where the person said to get it to fit requires modification.
One other sites list it as ‘universal’ fit. That’s a tough one.
I don’t know if this helps at all but here’s some photos of the mounts I have. Energy suspension. I just happen to have them out as I also need to install them:
Does anything look different?
Reactions: Dchichizola
