I can only speak to my setup, but i installed it per Paxtons instructions. I'll have another gander just to make sure i'm actually correct, but i believe I am in how i'm explaining my setup.
Edit: i am correct in how i was explaining it. The brass barb with the hose and metal check valve is where the line from the VC goes to (before MAF) into the airbox:
Progress Thread Post in thread 'Komo's 1990 GT - Parts Gathering Purgatory'
Supercharger install is done!
Got the fuel feed hardline out of the little bracket and that was it, elbow was so easy to get on with that out of the way. One thing I had to do is route the A/C hose in between the inlet and discharge piping. It has wiggle room so not pinching anything and it’s not bent all weirdly:
Then put the line from the oil fill tube to airbox:
From there it was just putting the discharge tube on:
Which basically wraps up the install.
I found the right hex head bit to put the breather on the...
What is that silver cylinder, a check valve?
ty drier vent inlet tubing they use in the kit. Also, remember i'm a low boost kit so maybe it doesn't really matter anyways.
