No Crank--have power(accessories)
chazmanaz
Got a 94 with a 5.0 transplant. Key on- all gauges,radio, windows etc work. Soon as i turn it to start, all dies, no click, nothing. Pulled starter guy(oreillys) said it did what it should do but the machine didn't pass it(he says its funny that way). i've replaced or improved both Pos & Neg cables. besides pulling it again to bench test myself, any other ideas?
One other strange thing Fuse #4 SRS module blows no matter what amp fuse goes in.
Thanks
Does the ground from the battery go from the battery to the engine block and then to the apron where the battery sits? Sounds like an insufficient ground. Good luck.
originally went from the battery to the starter mount bolt. Deleted that and now goes from battery to engine block around #5 Also has smaller wire that are bolted to core support. Thinking of adding a ground strap to starter bolt.
