Hey guys, I'm at a bit of a crossroad right now. I have the upper and lower intake off and I also have the factory headers off. I don't know if I'm going to be able to keep myself from making upgrades while I have the engine taken apart.
I bought a used set of Hedman shorty headers and off road X-pipe. The header fit is garbage and I'm not going to bash my floor in to make them work so they are off the table.
It seems kind of silly to put the engine back together stock but I'm trying to figure out what to do. So far, these are the options I have in mind:
1.) a light port on the factory E7 heads, maybe just remove the smog bump in the exhaust port, install the Cobra and lower intake I have and re-install the factory headers with an off-road mid-pipe.
2.) Install GT40 heads that I have on a parts engine, put a better cam in it- I'm probably limited to a factory cam since it's a Speed Density car. Maybe find a mass air HO cam? Maybe put the factory headers back on or upgrade to a set of SVE shorty headers.
3.) Go big and get a set of SVE 185cc CNC heads or Trick Flow 11R 190 cylinder heads, cam, headers- probably long tube headers, injectors, etc. I like this option but it is a Speed Density car so I would have to switch to mass air or maybe upgrade to some type of aftermarket EFI system.
When I bought the car my original plan was just to do short tube headers, off-road mid-pipe, and a 3.73 gear. The current project started because my valve covers were leaking, I had to take the upper intake off to change the valve cover gaskets. Since I had the upper intake off I thought it was a great time to upgrade to the Cobra intake, and well, you know how that goes, while the engine is taken apart, and it's winter, it would be silly to put the Cobra intake on factory heads and this gets the snow ball rolling!
My goal is to have a fun street car, that sounds good, pulls good, has enough power to slide the rear end around, etc. I really like the idea of making around 400 flywheel. I think that would be a fun street car but that would be option 3. If the car were mass air already option 3 would be easier, and cheaper, to pull off.
Anyway, just wanted to see what your opinions are. I should add that the engine compartment, and engine, are both pretty grimey. At some point I would like to pull the engine, clean it, clean the engine compartment, etc. Maybe right now I should just focus on getting a little more power out of the current setup and do option 3 if / when I get around to pulling the engine?
