I've been searching this site and googling everywhere and making me more confused as to the path to take.
I currently have bone stock 91 AOD 'vert with a leaking water pump and figured when changing the pump might as well cam it. Then, found out I can pick up a 2000 Mountaineer for free. I will be picking it up in about a month and trying to plan how to incorporate the heads, intake, etc. Plan to pull the engine and 8.8 rear end out of it and take the GT40P heads and intake and put on my Fox.
Eventually I'll probably tear into the Mountaineer engine and rebuild (as I just helped the FIL rebuild a SBC 350 over the winter for the first time and that went well)
But my questions are since GT40P heads don't have what is needed for smog/egr (and I'm not in a state where emissions is needed) so not sure what I need to do.
Remove smog/EGR?
MAF changes/mod needed?
Throttle body from Mountaineer use on the Fox or go bigger?
Injectors from donor use on Fox or upgrade to 24/30lb? (not interested in having to tune)
Cam/springs suggestions?
New timing set since I'm in there? Double?
Have a set of BBK1515 headers to resolve the plug angles. And plan to pick up 90 degree boots for Autolite 104s.
This is just going to be a street/summer runner, not track/race at all. I'd like to stay on the economic side, but I know I should replace/upgrade springs to match whatever cam.
What am I not thinking of?
Thanks in advance for reading thru this, looking forward to all the opinions!
Jason
Remove smog/EGR?
Jason
