Electrical Code 29 again
Creomod
5 Year Member
Sep 14, 2018
557
49
48
San Antonio,Texas
Ok guys I’ve been having issue with my car,last post I posed About vacuum leaks. My car running ragged not like it used to . I’ve checked everything I even sent my ecu back to ecu exchange & the problem to me keeps communicating back to the ecu.
I start the car run it up the street come back. No cel light ,run codes & I g eat code 41 so I swapped vss sensor still doing same thing. It’s not the sensor I tested it. Removed it put a voltmeter on it spun the gear by hand & yes it generates voltage.
So I ran voltmeter to neg battery terminal the other to the vss connector (green wire) and with key on I have no voltage . I should have voltage . Removed the ecu ,checked for continuity from pin 3(ecu connector) to vss sensor connector green wire good contuity same thing from pin 6 to the neg wire on vss connector good conituty.
Voltmeter from pin to pin on vss connector no continuity so I’m assuming that it’s not a wiring issue & I’m thinking my problem is that I have no voltage to vss connector so I’m think that’s my problem. So I just need input because they did the inspect it & said that they ran it on their test car and was looking at live date stream & accurate and it passed . I keep writing to them to send it back to take another look . I know you can test the ecu it’s self from pin to pin & I belive something is wrong I’m debating to take to altex & have the guy swap my capacitors & then test it from pin to pin
I'm confused. Not sure year or engine or any details. But isn't a 41 an O² code? Don't see why you're replacing a VSS for an O² code.
But regarding the VSS, it generates its own signal. You won't have key on power at the VSS plug. The two wires are the sensor output and sensor ground.
I’m sorry my mistake it’s code 29 that I keep getting
Check the wiring for resistance.
This thread is for a 92 but good info:
This thread was specifically for an 89 so the wiring diagrams are better suited for you.
Ok I tested egr it’s good now I’m at the resistance check now when I test from black /white wire from map/baro to black/white wire on the egr connector I’m getting 0.00 ohms. And when I go from same egr wire to the neg battery thermal I’m getting -0.01 what does that mean? I hmkmow I have the setting right on the voltmeter checking ohm the omega sign lowest setting I think like 20k….. actually from battery - to the map,egr,& tps it’s all -0.01 not sure if that means anything
