I’m finishing up my ’93 Notchback this Fall, 12th Owner: My '93 Notchback Restoration & Performance Build, by finally ordering a Maximum Motorsports (MM) K-Member. I plan to purchase all the associated hardware to run coil over struts in the front.
I had a good technical discussion with MM’s staff, but wanted to get current K-Member and suspension enthusiasts’ input as well before I pull the trigger. My concern is this, and I’d appreciate any feedback:
My car is 100% street driven and I’ll likely be going with the Bilstein Front Struts with 275 lb/in, 12” long, 2-1/2” diameter coil over springs. This is per MM’s technical suggestion for “Good handling on the street while maintaining excellent ride quality”. My concern is twofold:
1. Is 275 lb/in too soft up front as I’m coming from Ford Motorsports B Springs which are Front: 425/500 lb/in., Rear: 200-300 lb/in. I want good street manners, and a suspension that doesn’t beat me up, but I don’t want the car too lose.
2. If I go with the 275 lb/in coil overs, will that be compatible with traditional 200-300 lb/in rear springs? I was planning on leaving the rear 200-300 lb/in rate Ford Motorsports B Springs alone as the rear height is perfect and the car squats very nicely when accelerating hard. My car already has Bilstein rear shocks and a MM Panhard bar which was part of MM’s suggestion. So then the only addition from my current rear setup of Ford Motorsports B Springs, MM Panhard Bar and Bilstein shocks would be the addition of an Eibach 1” solid anti-roll bar.
Is there a formula or equivalence between non coil over springs, such as the Ford Motorsports B Springs rated at 425/500 in the front, and coil overs? It seems that MM’s suggested 275 lb/in is far softer than what I’m currently running. I’d like to get this right on the first try and have concerns about the 275 lb/in coil overs in the front with 200-300 traditional springs in the rear. Thanks
