I would go T56 magnum 6speed with 4.56 gears...The PO ran nitrous on it a few times, but mostly he ran it naturally aspirated (bracket racer stuff).
I on the other hand like to build my projects to be high horsepower dyno cars that can goto the track and lay down a fast pass.
In this case, I have decided to ditch the C4 transmission and put a TKX in the car.
I may run the nitrous at first to see what it makes, but ultimately I'd like to make this a twin turbo setup.
Ryan
The T56 Magnum is a nice piece. I ran one previously in my 2003 Mach1 project. But the T56 doesn't fit into a Fox without some cutting/modifying compared to the TKX which literally drops right in.
The 4:30 gears are not bad at all so far. In 5th gear at 60mph it only turns about 2,200 rpms.
Here's the latest video -
How many vacines did you get for bullIt’s just insane how much all of it has gone up since the Covid bs. I’m thinking about getting rid of the carb setup on my T-Bird so will be following the conversion on Civil War.
COVID when it first started I only had 2 skipped the rest and I was fine I got 2 Pfizer- shots. And not moderna supposed to be bad side effects from moderma.How many vaccines did you get for bullCOVID when it first started I only had 2 skipped the rest and I was fine I got 2 Pfizer- shots. And not moderna supposed to be bad side effects from moderma.
While cooler air is always better, my car does not have splash shields and would have lots of dirt/debris/water potential to get in/on the filter.Any real evidence that putting the filter in the inner wheel well would be better i.e. no wash and cooler inlet air temps?
