New Project Car - The Civil War Mustang
It’s just insane how much all of it has gone up since the Covid bs. I’m thinking about getting rid of the carb setup on my T-Bird so will be following the conversion on Civil War.
Reactions: TTSaleen
Two front bearing/hubs ( timken) and two upper AC Delco " gold " upper ball joints were over $500 dollars for my C4 suspension for my " other " project... ]
Got it converted to Holley Terminator-X computer EFI along with new fuel tank (cobra) with dual pumps (hellcat), 10AN feedline and 8AN return with Deka 80# injectors and E85.
Had Andrew Borodin (DREFI) write the base tune and it runs great.
Reactions: General karthief
The PO ran nitrous on it a few times, but mostly he ran it naturally aspirated (bracket racer stuff).
I on the other hand like to build my projects to be high horsepower dyno cars that can goto the track and lay down a fast pass.
In this case, I have decided to ditch the C4 transmission and put a TKX in the car.
I may run the nitrous at first to see what it makes, but ultimately I'd like to make this a twin turbo setup.
Ryan
I would go T56 magnum 6speed with 4.56 gears...
Reactions: TTSaleen
The T56 Magnum is a nice piece. I ran one previously in my 2003 Mach1 project. But the T56 doesn't fit into a Fox without some cutting/modifying compared to the TKX which literally drops right in.
The 4:30 gears are not bad at all so far. In 5th gear at 60mph it only turns about 2,200 rpms.
Here's the latest video -
Your videos are amazing.
Reactions: TTSaleen
How many vacines did you get for bull:poo: COVID when it first started I only had 2 skipped the rest and I was fine I got 2 Pfizer- shots. And not moderna supposed to be bad side effects from moderma.
How many vaccines did you get for bull:poo: COVID when it first started I only had 2 skipped the rest and I was fine I got 2 Pfizer- shots. And not moderna supposed to be bad side effects from moderma.
I didn't get any covid shots, boosters or other. #PureBlood
:cheers:
Civil War Update -
Spent this past weekend putting the interior back together.
  1. New carpet
  2. New front seats (Corbeau) with ultra low bracket on driver side.
  3. Console with updated cup holders.
  4. Added center arm rest.
  5. Double din radio
  6. New HVAC controls and cable
  7. HVAC vents and dash
  8. Shift Light
  9. New MOMO steering wheel
  10. Window trim for both doors (inside and outside)
  11. Replaced passenger side window motor
  12. New door arm rest pads and chrome trim
  13. New door attaching hardware
  14. Finished the trunk area with mat, nitrous bottle install, and battery cut-off switch.
  15. Made a cold air kit with 3.5" filter for the engine
  16. Had valve covers welded with 12AN bungs and hooked up a separate catch can
Any real evidence that putting the filter in the inner wheel well would be better i.e. no wash and cooler inlet air temps?
While cooler air is always better, my car does not have splash shields and would have lots of dirt/debris/water potential to get in/on the filter.
I am modifying the current setup to put the filter closer to the headlight and further away from the headers.
