4.6 spitting o-rings out of 2 injectors
Confused. When do you get the 90psi? Explain the exact
Conditions
i drove 25 mins home from work (highway) - was watching the FRP and it jumped up 51 3x and thought it odd. Anyhow, I got home and realize if i turn the key back i thought i was only goin back 1 click but was going back 2 click and shutting off the scanner - so I moved it forward 1 click and it started reading fuel pressure again. It was like at 50 then kept slowly creeping up. I took stills and video of it - i was able to duplicate it twice by starting the engine again and watching it again.
I just got back from skiing and mustang was cooled down so I turned the key to the same exact spot but didn't start it and it read a constant 47-48 PSI. I started the engine and ran it 30 seconds and running 40 psi at idle and then turned the key back to just on and it stayed at 48 PSI again. so this is what I think is expected, BUT what I saw around lunch time was reading 90 psi. I figure that after it heat soaks a bit it's probably jumping to 100 psi and pushing that fuel rails up and orings out.
so what fuel pump is a good one or doesn't it matter the brand? I can hit up rockauto or just a parts store.
THAT!!!... Peaking to 51psi is nothing to worry about, let's be honest here, blowing that rail off and BENDING THE RAIL HOLDS which was the OP would be sick pressure man, no way no how... Please replace your rail... Unless you have the incorrect length injectors, I mean bro some cars we run @OVER60-80PSI on E85 no problem EVER!!!...
Mark
Mark
Don't start throwing parts at it that won't change anything (FUEL pressure and FUEL PUMP IS DOING EXACTLY WHAT IT IS SUPPOSE TO)... Either buy the eBay rail or preferably buy a good upgraded one and call it a day, no fuel pressure is going to BLOW that thing off unless you have a different issue, you showed us a photo of a BENT rail... I agree hypothetically bending it back would be OK but those fukers' are tough metal too, maybe it has a bad connection/weld where the bracket connects to the actual rail, dig in deeper...
Mark
Mark
i don't know, maybe your right but i will verify it tomorrow afternoon once I get my analog gauge adapter.
Reactions: highplace11
so i was able to duplicate the 90 PSI with a analog gauge. I took the car for good ride, shut it off and hooked up the analog gauge. Then ran it a few minutes and shut it off and took out the key - the gauge read 40 psi as soon as I shut it off. i watched it slowly rise from 40 to 91 - it took 10 mins
PS - i had to replace the Schradar valve/port to get my gauge to work. Old one had too short of a pin.
PPS - my analog gauge exactly matches whatever the scanner says.
Doesn't this point to the fuel pump check valve? I think I've ruled out the FRPS, right?
so i pulled the tank today and put a new pump in. The old one was a Delphi FG0827 (with a 2024 date code) and the one ordered was the same Delphi pump. It didn't fix the problem - I'm pretty confused right now what else it could be unless it just doesn't like these Delphi pumps. :fuss:
Very interesting.
Pressure still increases AFTER engine/key are off, correct?
For fun - I ran this through GPT. Use any GPT advice with caution BUT :
The Delphi replacement pump for the 1999–2004 Mustang GT is notorious in the Ford community for having an over-engineered check valve that lacks the proper high-pressure bleed-off (PPRV) threshold. While Delphi makes excellent electronics, their mechanical returnless fuel pump modules for this specific Ford generation behave like a completely locked hydraulic dead-end when the key is turned off.
Why the Delphi Pump is Twisting Your Fuel Rails
When your car shuts down, heat soak from the 4.6L V8 transfers directly into the metal fuel rails. The trapped fuel expands.
  • The Factory Pump: Designed to crack its pressure relief valve open if heat expansion pushes pressure past ~60 PSI, safely venting it into the tank.
  • The Delphi Pump: Does not bleed off. It locks up tighter than a hydraulic jack, forcing the pressure to 90–100+ PSI until something physically gives way—which, in your case, is the metal injector hold-down tabs and the rails lifting.
Your Actionable Fixes
Because you have confirmed the pump brand, you have two direct paths to permanently fix this and protect your fuel system from mechanical damage:
  1. Modify the Current Pump Assembly (PPRV Delete):
    If you do not want to buy another pump, you can pull the Delphi unit back out of the tank. Inside the pump hat, you will find the plastic PPRV (Positive Pressure Relief Valve) assembly. You can completely bypass this valve by replacing it with a short section of submersible fuel line hose (specifically rated SAE 30R10, such as Gates Submersible Fuel Line Hose) and stainless steel fuel injection clamps. Removing the restrictive Delphi valve completely eliminates the physical lock, preventing any future hydraulic pressure spikes.
    • Note: The only side effect is that fuel pressure will bleed off normally when parked. You will simply need to turn the key to the "ON" position for two seconds to prime the system before cranking the engine.
  2. Swap to an OEM-Spec Pump:
    Return the Delphi pump and replace it with a genuine Motorcraft unit or a high-performance drop-in assembly from brands like Walbro / TI Automotive. These brands use internal check-valve architectures that safely release thermal expansion pressure back into the tank without locking up.
Reactions: gkomo
i put in a different pump that I got from LMR. I cleaned the tank and changed the filter also. Everything is good now!! Dozens of trips and the fuel rail has stayed perfect. I think i might have jumped the gun thinking the 2nd Delphi pump was an issue, so I'll probably just sell it since it just has 1 hour on it or keep it for a spare.
thanks again guys for all the helpful posts! My wife is a happy camper now
Reactions: squeak93 and gkomo
What else did you change aside from the pump? Did the 2nd delphi make the rails crack open too?
Changed pump and the filter. My initial test in the driveway was positive with new Delphi pump. Stayed at 28 psi (analog gauge) after letting it run for 15 mins and turning the key off completely. I didn't drive the car enough to see if rails would crack open b/c when I put the new Delphi pump in I forgot the fuel level float... i didn't catch that until went in house to give my wife the 2 thumbs up and there it was on the table. I was pretty mad at myself!! I decided why not take the car for a ride... for kicks I hooked up my scanner and saw fuel pressure rising again after I turned the engine off but left the key to ON. That perplexed me for sure and assumed same issue. Wife did not want to drive the car without a working fuel gauge so it sat.
Fast forward a week and the new LMR pump does it as well. That got me thinking that might not be a scenario that happens in real life. So hooked up the analog gauge and it stayed at a good PSI after shutting it down completely. I don't want to change pumps anymore so the LMR is staying in there. I honestly don't know what solved it.
