Fox Traction control
You can use the stock VSS sensor on the speedo for the rear wheel speed, and then just add one to the front wheel. Compare the trans output shaft speed to the front wheel speed in the MS3 and bingo, traction control. I'm going to try the method @nicholase mentioned first though and see if I can make that work the way I want.
I'd at least look into it. Mine works awesome.
Like most things there's old school methods and more modern approaches.
I'd research what it uses as inputs. If its similar to mine it should have inputs for RPM and VSS. It should also have your transmission gear ratios entered and final drive. This way it knows actual vehicle speed and what gear you're in. Lastly it would use code to determine actual vehicle speed even when the tires are slipping. That makes it work really well to dial in heavy ignition retard in first gear and taper off as vehicle speed increases and you shift through the gears.
I know we're talking about different management systems here, but if you or anyone is curious how modern ringless TC can work its on page 61-65 of the resource I uploaded. It might give some insight on if the MS setup is similar or not.
https://stangnet.com/mustang-forums...e-management-system-install-instructions.111/
Re reading the screen shot I posted it might be a different style setup from what I'm using.
Reactions: Sparky714
Upgrading from a Megasquirt DIYPNP to a MS3Pro Ecu this winter so I have more options for inputs and outputs. The biggest one I'm looking into doing is traction control. I know the easiest way is to upgrade to SN95 spindles and use the antilock brake bracket for the front wheel sensor, but I have three full sets of 4 lug tires and wheels, so I'm not interested in going 5 lug. I've found some information on guys making their own brackets for a hall effect sensor and using the back of the wheel studs as pickups. But from what I'm reading, it doesn't work great at low speed. You need a reluctor wheel with more teeth. Has anyone modified a sensor wheel or had one made to work on a stock 4 lug brake disk?
best traction controll for me is a pair of Mickey Thompson ET Street SS tires or Nitto NT 555R2 tires.
My RPM per gear solution in Father Time:
I think my Big Stuff 3 has been upgraded to the "SR2" version that does this based on driveshaft acceleration. I never got the DSS to work. Will take another shot at it, next year.
Been running ET Streets for quite a few years. They defiantly help on the street, Looking to improve consistency at weekend track days. Consistent launches on slicks isn't easy with a manual transmission. At least for me anyway. I also like tinkering with stuff like this.
I'm currently transferring tables and setting from the old to the new. There is a ton of more options on the MS3. Traction control has Perfect run, Perfect run RPM, VSS % slip and a bunch of settings under each of those. Should be fun seeing how this works.
Reactions: nicholase
