Personally I think you spent some money unnecessarily! Them lower pulley rings ain't cheap. You could have achieved the same amount of boost with an upper pulley only (2.80) for a lot less money.
Word of caution for everyone.... Unless you are running a ported Eaton, spinning the stock blower that fast will only cause more parasitic loss and gobs of heat soak. Not to mention the added stress to the alternator because you are over-spinning it with the 4lb lower.
The M112 is rated at a maximum RPM of 14,000 by the manufacturer, although the Lightning guys have been spinning the piss out of them for a couple years now with very few failures. Using the following equation (lower pulley diameter (stock=7.625), divided by upper pulley diameter (stock=3.65), multiplied by max engine RPM (6500) = max blower RPM.
7.625 / 3.65 X 6500 = 13,578RPM's.
Lets take a look at some of the available pulleys and their max RPM's.
Pulley Dia./Blower RPM
3.65 / 13,578
3.40 / 14,577
3.20 / 15,488
3.10 / 15,987
2.93 / 16,915
2.80 / 17,700
2.76 / 17,957
I think a Metco 4lb lower pulley is roughly 8.5 inches in diameter, so using that figure we get the following for your current set up:
8.5 / 3.65 X 6500 = 15,137 Blower RPM's.
Add the 3.10 and you get:
8.5 / 3.10 X 6500 = 17,822 Blower RPM's.
This is roughly the same as a 2.80~2.76 upper.
U.M.
