LaserRed01GT
Banned
Not flaming but I rarely if ever have seen VT Stage 1's hit the magical 300 mark w stock heads..I put down 303/318 w the 2's
I think you need to read this thread again. Nobody ever said anything about busting the 300 mark.
read your f'ing posts again, you stated a stage 2 cam would not make more power on a stock head than a stage 1 and you are WRONG.I think you need to read this thread again. Nobody ever said anything about busting the 300 mark.
why is it when i pop into tech over here every so often these noob guys are post whoring it up giving out bad info??
No you are wrong, and I have read most of your posts on this board and there is one common denominator with all of your posts....you are constantly being corrected.
Like I already said, in most cases a stock headed motor will show greater gains and will perform better with Stage 1 cams than a Stage 2 cam on that same stock headed motor. Don't believe me, call VT or MPH. You are just showing all of us that you don't know much about camshaft and cylinder head flow dynamics. Bigger cams do not always make more power, especially on a stock 4.6 head.
There is an emissions mask(swirl dam) within the combustion chamber of a stock 4.6 2V head. Stage 1 cams take this into account as just a part of the chosen grind. The increased duration, lift, and overlap of the Stage 2 cams is not optimal for working with the stock heads. The increased flow/velocity off the seat of the Stage 2's would induce excessive vortices within the CC and would keep the Stage 2 cam from making ideal power on a stock head especially in the low/mod RPM range under load.
Stage 2's are meant for a ported head. The deck of new cylinder heads is always milled(roughly .010") to make the deck is "true" as so the head gasket will seal as good as possible. How much they are milled will effect the quench height and consequently the SCR. Stage 2's are ground to optimally work with this reduced quench height.
I'd watch who you call a noob. There are plenty of technically savvy guys on this board, and I haven't read one single post from you lending any competent technical advice. As for my knowledge and expereince with these motors, there are plenty on here who can vouch for me.
Some people must learn the hard way though... Hmm.... "stage 20 cam is bigger than stage 3... must make more power..."i guess every single stock headed 2v with stage 2 cams has made that has made more power than similarly modded stage 1 cars are just flukes, flukes that consistently made more power. your speculation must out weigh the real world results.No you are wrong, and I have read most of your posts on this board and there is one common denominator with all of your posts....you are constantly being corrected.
... I'm sure you just confused some people with this.Some people must learn the hard way though... Hmm.... "stage 20 cam is bigger than stage 3... must make more power..."
I have personally seen too many cars lately with $1,000's in over the top mods (like a full race ported head and a t66 on a sr20det *2.0L 4banger for those not in the know*) when they still have a stock bottom end and fuel system....
Then they get pissed when I could only make 320hp out of their car. "But this turbo is good to 500..."
If none of the following stood out as being blatently wrong, you are one of these people.
And yep, some just have to learn the hard way. That's ok, the internal combustion motor God's only want a select few in the know anyhow.one of those quotes is from a post on MD and it was about a totally stock gt with stage 2's, flowmasters and an mph tune. it put down close to 260rwhp with no losses anywhere and made 50+ rwhp more close to 6k rpms.Did some searching on VT's forum and it seems like they recommend Stage 2's over Stage 1's if you can do the valvesprings for the 2's. ANd no it's not because I'm selling stage 2's. I did my research before i bought the 2's and HP is why I chose them over Stage 1's.
Quoted from Jim himself about a '99 with some bolt on's and no headwork, "Stage2 n/a's if you plan on changing the valvesprings, stage1 n/a if you don't want to change springs." and after asked about RWHP, "~20-25rwhp peak to peak, but after 4000rpm you'll see gains as much as 35rwhp+ over the stock cams. The stage2's also love spray. They'd be your best bet, if you don't mind changing the valvesprings."
Another thread about "mostly stock engine and what cams?" To which Scott from VT replied, "stage2's with a spring upgrade. they luv giggly gas. Totally streetable. No noticable lose down low at all."
And here's all I could find about his opinion on Stage 1's. Again from Scott at VT, "Stage 1's work well, don't require springs, but its recommended. I have no idea of your mechanical ability, so I can't really say how hard they are to install. If you're mechanically sound, its not bad at all. If you don't know how to put gas in your car..... you could be in trouble"
No flaming intended. I like discussion threads like these. I don't build engines so I can't tell you about swirls dams and stuff but so I listen to what "those in the know" say. So I look to Jim and Scott from VT.
BTW, long time no see Jackie and why do all your threads turn into flaming fun.![]()
