10lbs with gt40p
95horse
9
i am wanting to put a vortech supercharger on a 95 mustang i have gt40p heads with 1.94 and 1.54 cobra upper ported lower b303 off hpipe ya da ya da ya. iwas wondering at 10 lbs of boost would this be safe with the add compression from the p heads and how much flywheel power could i expect.
if the tune is right, the bottom end is in good shape, and all of the supporting mods to the fuel system are done, you should be ok. i would run a compression and leakdown test though first just to make sure the bottom end is up to the task. as far as power output goes, that depends greatly on the rest of the mods you have and the tune. somewhere around 400hp at the wheels would be my best guess.
