Progress Thread "12th Owner": My '93 Notchback Progress Thread
  • Sponsors(?)
TOOLOW91
7,093
234
S.I.NY
I appreciate your help, but I'm in the research phase right now. I'm trying to figure out all I need and I was concerned that no hubs or rotors were included in the parts list. Part of the reason for the LMR kit is that it's all inclusive, but the downside is that I would be paying a 15% surcharge over identical Rock Auto parts. I'm catching on.
Lmr kit being all inclusive doesn’t help you when they are selling you spindles you don’t need and then still won’t sell you the stuff separate anyway . Also doesn’t include the brake booster which you need , the adjust prop valve , plug for the stock one ( I see the valve in the pics but not on the parts list ) . Also sticks you with the 11.65 rear cobra rotor which is fine if you don’t plan on putting a 15 inch wheel on . If you want to run 15 inch wheels in the rear to play at the track ever you’re better off with the gt setup for the rear . Which is how i linked it to you and have on my own car as well. Calipers are the same just rotor dia is bigger
Mustang5L5
i'm familiar with penetration
Mod Dude
Feb 18, 2001
32,827
8,971
224
Massachusetts
I did my setup for about $1.3k and that's includifing some of the extras like MM stainless brakes lines and crissdrilled rotors and such.
I sold off a bit of my stock stuff too and made bsck a couple hundred
Plus then you don't have SVE branded on your calipers.
  • Friendly
Reactions: TOOLOW91
TOOLOW91
7,093
234
S.I.NY
Did. I miss anything in my lists ? I know i relied heavily on your thread and your advice esp on master sizing Vs calipers when I did this on my car and for stock brakes this thing will make you eat the steering wheel.
Mustang5L5
Mod Dude
Feb 18, 2001
32,827
8,971
224
Massachusetts
You nailed it.
I always say to use the old m-2300-k instructions as a guide
As for the parking brake, there's a clip available now to avoid cutting and welding and it will allow you to tighten the cable later inside the car.
Also, LRS has the rear axle brake lines to avoid adapters and bending. For the cost though, one may just want to use the $5 adapters.
I always said going 5-lug Cobra disk was one of the most fun and rewarding projects I ever did on my car.
Reactions: Mstng93SSP
Habu135
Advanced Member
Jan 10, 2019
515
305
73
39
California
You nailed it.
Awesome. Thanks! I just printed out those instructions. That's a great reference if I decide to piece all the parts together from Rock Auto and elsewhere. As for now I think I'm leaning with purchasing the majority of the miscellaneous parts from LMR and going with other vendors for the larger parts (rotors, brake pads, etc.) I suspect I can buy better parts for about the same price from Rock Auto and other vendors than going with the package LMR rotors and stock type pads.
Habu135
Advanced Member
Jan 10, 2019
515
305
73
39
California
Did you guys use your existing Power Brake Booster? Obviously you upgraded to the correct Master Cylinder, but from my research it seems that going to an upgraded/larger Power Brake Booster is unnecessary. Thanks
Habu135
Advanced Member
Jan 10, 2019
515
305
73
39
California
ACDELCO 18A964A Front - 65.78 for pair .
ACDELCO 18A654A - Rear 29.76 for the pair
Quick parts check on Amazon. The 18A964A (front rotor) is $22.75 a piece! Rears are $14.83 a piece!! Dang
Actually, it looks like 18A654A is actually the smaller GT rear rotors. 18A1262A may be the correct larger (11.65") '03-'04 rear Cobra rotors?
Habu135
Advanced Member
Jan 10, 2019
515
305
73
39
California
Ya, those SVE graphics are dumb.
TOOLOW91
7,093
234
S.I.NY
In my earlier post I said I sent you the rear gt stuff because the stopping power is the same but allows you to be able to fit a 15 inch wheel on the rear to be able to drag race . If not you can opt for the cobra rotors but also get the correct NRC backing plates on lmr because that’s the difference
Habu135
Advanced Member
Jan 10, 2019
515
305
73
39
California
I need to know if I'm on the right track with this for a full '03-'04 Cobra style kit:
AC Delco 18A1262A (rears) and the AC Delco 18A964A (fronts) are correct, right?
Calipers: Centric 14161098 (front left), Centric 14161097 (front right). AC Delco 18FR1440 (rear left), AC Delco 18FR1439 (rear right)?
I've spent quite a bit of time researching Rock Auto, but there is always a little bit of concern that these descriptions/ applications may be off. Thanks
Habu135
Advanced Member
Jan 10, 2019
515
305
73
39
California
Between Rock Auto, LMR and Amazon I'm looking at $1,715. That's with AC Delco front and rear rotors, Centric front calipers, AC Delco rears. Stainless steel brake lines and Hawk HPS 5.0 pads + all the miscellaneous fittings/lines. So it's a small savings over the LRM kit with some upgraded parts.
Habu135
Advanced Member
Jan 10, 2019
515
305
73
39
California
No Vehicle Specified
ACDELCO​
18A1262ARotor
$ 23.79​
$ 0.00​
2​
$ 47.58​
ACDELCO​
18A964ARotor
$ 32.89​
$ 0.00​
2​
$ 65.78​
DURAGO​
29599000 (295-99000)Spindle Nut
$ 3.47​
$ 0.00​
2​
$ 6.94​
RAYBESTOS​
MC390217Master Cylinder
$ 67.79​
$ 0.00​
1​
$ 67.79​
TIMKEN​
513115Wheel Bearing & Hub Assembly
$ 36.79​
$ 0.00​
2​
$ 73.58​
2004 FORD MUSTANG 4.6L V8 Supercharged
ACDELCO​
18FR1440Caliper
$ 62.79​
$ 60.00​
1​
$ 122.79​
ACDELCO​
18FR1439Caliper
$ 62.79​
$ 60.00​
1​
$ 122.79​
CENTRIC​
14161098 (141.61098)Caliper
$ 51.79​
$ 75.00​
1​
$ 126.79​
CENTRIC​
14161097 (141.61097)Caliper
$ 50.79​
$ 75.00​
1​
$ 125.79​
Discount​
$ -24.50​
Shipping​
Ground
$ 73.85​
Tax​
$ 62.72​
Order Total
$ 871.90
Visa​
-$ 871.90
Balance Due
$ 0.00
[TD]Part Number[/TD]
[TD]Part Type[/TD]
[TD]Price EA[/TD]
[TD]Core EA[/TD]
[TD]Quantity[/TD]
[TD]Total[/TD]
[TD][/TD]​
Your credit card will be charged when your order ships.
TOOLOW91
7,093
234
S.I.NY
You need the booster . I sent it in my list and noted it several times . 1993 cobra booster . It’s listed in my initial list with the part numbers in text . 94-95 cobra master cyl . * This is important to follow *
The only things you need to change are the rear rotors and calipers from rock for the rear cobra stuff . Then on my cart from lmr swap the nrc caliper backing plates for the cobra specific ones .
Your calipers look fine for what you want I just checked . As long as the description says Svt cobra you are good
Everything else I sent you will work . The research is done for you .
Habu135
Advanced Member
Jan 10, 2019
515
305
73
39
California
Pulled the plug. It was over $2K, but I got Hawk HPS pads, Maximum Motorsports stainless steel lines and quality rotors and calipers (primarily AC Delco). Thanks everyone!
Reactions: Rdub6 and TOOLOW91
TOOLOW91
7,093
234
S.I.NY
Glad to hear it . You won’t be disappointed you did it this way. The lines and stuff make a big diff in pedal feel . Don’t forget to gut both sides of the stock prop valve . Old plug goes back in the rear new plug goes in the front from lmr . When you bleed the Brakes make sure the adj valve is full open so you get full fluid to the rear to get the air outthen adjust it .
TOOLOW91
7,093
234
S.I.NY
Good choice. If you have any issue, let us know. Fairly easy swap that you'll love when done
I don’t know why I waited so long or was intimidated by it . Was the best thing I ever did. ESP going high 10s on stockbrakes . No fun
Mstng93SSP
You have a nice rear end there Dave.
2,108
174
Mililani, Hawaii
Swapping the cobra booster in is an absolute must. There are a couple of tricks to make it go easier. There have been numerous posts about swapping in the 93 cobra booster that can probably help you.
Chris
Rdub6
Mustang Master
Dec 29, 2017
1,317
970
123
Long Island, NY
I kinda had that “intimidation” feel at first too. But then I just said “its all nuts and bolts” just take your time, get the right parts, and have at it. Now I just can’t wait to get the rest of my list all ordered and get to it. I’m hoping it gonna be this winters project.
Thread starter Similar threads Forum Replies Date
roushcollection Mid West Mi-roush Driver Autograph Session, Car Cruise-in & Open House June 12th 2014 Regional Forums and Event Information 0
marshall x $90 Track Day At Willow Springs- Streets Of Willow- August 12th Socal Regional Forums and Event Information 0
J August 12th American Muscle Show Cruise For Those South Of Philly Regional Forums and Event Information 0
KonaGTguy Pony Wars May 12th Valdosta/Adel, GA Regional Forums and Event Information 0
marshall x $125 Track [email protected] Springs-Big Willow-June 11-12th in Socal Regional Forums and Event Information 3
281cammer Fayetteville/Hope Mills NC Cars and Coffee March 12th Regional Forums and Event Information 3
T TPS Motorsports & Norcal SVTOA 6th Annual Toy/ Food Drive & Car Show-Dec 12th Regional Forums and Event Information 1
stangman98 Midwest Radial Race June 12th Regional Forums and Event Information 0
rays197 June 12th Hampton Roads Cruise Regional Forums and Event Information 1
B 12th Annual Ford Fever Classic / Aug 16th Regional Forums and Event Information 3
MRaburn Classic Design Concepts Open House - Aug 12th 2009 StangNet Site News 0
Cobra Jay NMRA JDM Engineering SUPER STANG @ Milan jUNE 12TH & 13TH 2009 Regional Forums and Event Information 1
CRUZIN Tasca ford 12th Annual Mustang Show Regional Forums and Event Information 1
M Sunday July 12th 2009 TRACK DAY TGPR Regional Forums and Event Information 0
RStangsOC SMA 12th Annual Mustang Show @ Santa Margarita Ford Regional Forums and Event Information 3
'68StangGT Mustang Muscle at Montana West = July 12th Regional Forums and Event Information 2
M July 12th Northend Cruise Regional Forums and Event Information 4
7 Merchantville NJ. Car Show July 12th Regional Forums and Event Information 1
2 Bootleg Mustang Car Show April 12th Regional Forums and Event Information 55
G My Baby is Due Dec. 12th... 2005 - 2014 S-197 Mustang -General/Talk- 10
A Columbia Maryland Car Meet Sunday August 12th Regional Forums and Event Information 2
SRT Handz Powered by FORD!!! May 12th From Ford Headquarters in Irvine *PICS!!!* 1996 - 2004 SN95 Mustang -General/Talk- 14
R Cars and Coffee: POWERED BY FORD!!! May 12th 2005 - 2014 S-197 Mustang -General/Talk- 3
CobraRed_96_GT Gallop Around the Bay III, Saturday May 12th, 2007 Regional Forums and Event Information 0
5 Arizona cruise/bbq sat may 12th Regional Forums and Event Information 1
M LA CRUISE DETAILS: Saturday May 12th Galpin Auto Sports Regional Forums and Event Information 2
Joey5.0 Local Meet Friday Jan 12Th Regional Forums and Event Information 63
T MIAMI MEETING, OCTOBER 12TH, 2006, THURSDAY Regional Forums and Event Information 1
D Sanair show, August 12th question Regional Forums and Event Information 9
stock50LX Pacific Raceway (Auburn) first TnT February 12th Regional Forums and Event Information 47
stangtrooper97 Hooters GTG- Saturday 12th. Regional Forums and Event Information 10
Evo Performance Evolution Performance Dyno Day - Saturday, November 12th! (PA) Regional Forums and Event Information 4
S Well,... I might be there on the 12th Regional Forums and Event Information 6
awwyea NEBOC Lobster Buffet Dinner Friday Nov. 12th !!!! Regional Forums and Event Information 24
S Dec 12th... 1st Annual Toys For Tots GTG/Drive Regional Forums and Event Information 3
dark_cobra_01 Weirs Beach/Funspot Cruise (NHMC car show Sept. 12th) Regional Forums and Event Information 49
C Sept 12th. Alberta's Fastest Streetcar Shootout Regional Forums and Event Information 1
T All Ford Race and Car Show on September 12th Regional Forums and Event Information 0
A WANTED: video footage from woodburn june 12th Regional Forums and Event Information 0
Stedda LMMC-CT Springfield MA Hooters Meet! June 12th! Regional Forums and Event Information 12
CTGrey02 June 12th, LVD Ford Day Regional Forums and Event Information 27
gajos New Member and Mach 1 owner The Welcome Wagon 3
J New '65 convertible owner The Welcome Wagon 4
A New member from Ontario Canada, owner of a 2020 Mustang GT 2015+ (S550) Mustang -General/Talk 1
R Canadian 77 owner The Welcome Wagon 4
A New fox owner, idle issues need some advice Fox 5.0 Mustang Tech 12
S Old Foxbody owner looking to own again. The Welcome Wagon 4
I New Mustang Owner Here The Welcome Wagon 2
M Help please new mustang owner 2005 - 2014 S-197 Mustang -General/Talk- 2
0 New to the Forum, new s197 owner from So-Co The Welcome Wagon 2
