19# or 24# injectors with my combo?
  • Thread starter Thread starter RTGreen
  • Start date Start date Sep 14, 2004
RTGreen
1,866
Alabaster, Alabama
Sep 14, 2004
  • Sep 14, 2004
I'm in the process of buying some used Edelbrock Performer heads at a great price. I already have LT headers, Accufab 70mm TB, and C&L MAF(19#). Should I step up to 24# injectors? None of the items are installed yet and I'm still looking for a used Cobra or GT-40 intake, but I needed to know if I need to be rounding up some 24# injectors and a 24# sampling tube?
Thanks,
RT
D
Daggar
3,902
  • Sep 14, 2004
Your stock injectors should be fine. I don't see a cam listed anywhere in your setup. At most,(but I doubt it) you may need an adjustable fuel regulator. The folks really familiar with MAF can confirm or deny that, but I don't see anything in your setup that would suggest that the 19lbers couldn't handle it.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Sep 14, 2004
  • Sep 14, 2004
IMHO you best off saving your $$ cause your probably get best results upgrading your MAF-injectors-fuel pump, then you can be safe and provide enough fuel without maxing out the system.
RTGreen
1,866
Alabaster, Alabama
Sep 14, 2004
  • Sep 14, 2004
I have a 190 fuel pump and adjustable regulator as well....sorry I forgot about those. I do need to pic a cam though. Thought about going with a TF stage 1.
PhLoBuS
473
Beverly, MA
Sep 14, 2004
  • Sep 14, 2004
I am going to get 30lb injectors once i get a few more upgrades because i plan on keep modding and eventually those 30lbs will be perfect
NKau
1,346
Jefferson, WI
Sep 14, 2004
  • Sep 14, 2004
With heads, I would definitely say go with the 24 lb. injectors. 300 fwhp is usually the limit for the stock injectors, and you should be above that.
G
gt90stang
568
  • Sep 14, 2004
RTGreen,
My 90GT 306 NA has performer heads, intake, 70mm tb, 73mm C&L, 24# injectors, Crane 2030 cam, 8.92:1 compression...way more stuff. The bottom line is I hit 85% injector duty cycle so 19# injectors wouldn't work for me.
Good Luck, Don
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Custom tune?
  • Nostang25
  • Jul 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 17, 2025
FastDriver
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
I
Engine Insane fuel trims +25% LTFT Bank 1, -16% LTFT Bank 2
  • imw_stl
  • Aug 31, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 19, 2025
Mustang5L5
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
