For whatever reason I got more out of the YouTube video than I've been able to get from this whole thread. :poo:ty attention span I guess.
Anyways, I want to commend you on an excellent job. I know the car isn't finished yet but I'm extremely impressed with the thought and craftsmanship behind the project.
Hopefully everyone can appreciate the kind of hours and commitment it takes to redo every single aspect of a car like you've done.
Alright, enough of that. Carry on :flag:
OK that's safe enough. whatever number you get for the 90ish kpa range add 20% and use that for the 135kpa range... (135kpa is 19.7 psi or 5psi boost)
Whatever the hell you just said....:crazy:
Naww JK,....I got you. So,...I can't just let it auto tune while I drive it around?....Don't we set some target AFR up there in boost territory and let the thing tune it to that?
Yes and no.... I do not auto tune the power section of the tune. the lambda delay is too great for the system to work effectively. (This is JMO lots of people auto tune the entire fuel map just fine).
I like to make a pull and review it in megalog viewer, then make changes from there.. you can even use the ve analyze function (basically auto tune but works using info from the datalog) this feature allows you to set the lambda delay from the log, I use a delay of 5 and it works very well.
Reactions: 90sickfox
Well I have 5 days off next week starting Sunday. Buffing the car is next (Only have the drivers side done, and even that still needs more work with a foam pad) But I can't imagine that taking more than 4-6 hours at most.
After that's done, I gotta do something with the trim to get it to fit around the rear glass....dude installed my rear glass a little too high, and I think the gap might be too narrow for the trim to snap in. Then again,....I didn't really try after the paint started flaking off.
When I brought it back into the driveway, and shut it off, the starter did some weird sht. Especially after dogging Collin, @hoopty5.0 ,...I may have some BS hot start thing going on myself,....seemed real weak, and kicked out too easily while cranking.
Again,...this is after one test drive,...so....
I gotta get the little japanese kid hooked up,....This should be a killer audio system,...and I'd like to hear it.
The trunk needs adjusting, and that means I gotta convince #1 to let me shut him in there so that the thing can be adjusted closed,...and under the pressure that the lift struts are placing on it,....So I cannot install the vent for the G fin until I do that. The G fin is the exhaust for the G gills,..and a requisite part of the intercooling system,...so before any attempts to put it in boost....... gotta adjust the trunk while I have his little ass here for Thanksgiving.
It appears that I either have a loose connection at the headlight switch, or a bad switch. When you pull out the switch to engage the lights,....they flicker,...messing with the switch makes that better or worse....Getting to that switch now that the dash top is on will be a bad thing.
Additionally, I've wired the high beam indicator to the wrong output. gotta fix that too.
The rear cyclone emblem looks cheesy when illuminated....the strip leds that I used are inconsistant,..and several of them are out, so the first and last letter isn't lit......HATE THAT! That is a low priority though,.....I'll put it on the back burner list for the next few cold months.
The fuel system needs a small rethink....(again)....Right now there is a -8 hose feeding the first filter that is bent 180 degrees, and it's visible. It looks like this:
Bad dog.....Baaaaddd Dog.
I'm gonna raise the rear an inch. I want the rim to have the same gap that the front rim has. That will make that hose even more visible from behind,...so That'll have to be done as well.
She's gorgeous Mike! Glad you got all the leaks worked out. I'm not a big fan of orange but it gives life to that square a ss fairmont body...along with all the other custom modifications you made to the body. This is why you are one of the guys I look up to on here. So is it time for dancing bananas yet?????
:banana::banana::banana::banana::banana::banana::banana:
P.S. I can't wait for that video production of the "finished" Monster aka The Cyclone. :hide:
Thursday was my "late day" Since that left me w/ a couple of hours in the morning, I decided to fix some of the other issues that I talked about in my last update.
The top of the doors have trim on them. That trim is sht. There were/are so many dents, I'd have to add filler to them to make them decent, but even after that, I'd have to find the specific clips to re-install the damn things. Ford originally used a clip that looks like an "S" w/ a little spring wire to keep it there. It had a barb stud that would just pop into one of the 8 or so holes on top of the door.
Since this was a barb stud,..and you had to get you hand finagled into the door and try to crimp that barb so that you could remove that clip that held that molding,..What do you think I did to get the damn thing off back when it was first removed?
If you guessed anything that had the words "pry" in it,..you'd be close. I destroyed all of those clips trying to get the thing off, and they seem to be obsolete,...replaced now with an equally miserable to install threaded stud version.
Like I said before......I ain't taking that door apart to install that dented up assed trim.
So,...First thing I did was go to my metal supply store, and but two 3/16 thick x 1.250" wide pieces of aluminum bar. I'll run one edge over w/ my router to round it off, and then prime, and paint that thing.
Then I'm sticking it to the top of the door w/ 3m trim tape.
Da-Done-Dah!
I flipped the wires so that the high beams are "high beams" according to the indicator on my gauge display. Seemed like the easier way to solve that problem.
I raised the car in the air so that i could let the rear hang and run the adjusters up to add the ride height to the rear.
Annnddd....... I think the driver side strut threads are seized.
I wish I had tried the passenger side first, then I'd know that there was a problem, because the passenger side went up way easier. Even with the rear hanging, the shock itself keeps the rear from dropping completely, and that means that after the first inch of adjustment,....you are back to loading the chassis by turning the coil over nut. In other words,..you are lifting the car by turning a nut................. With a stupid little hooked wrench that looks like some sort of Pirate invented it.
Since I didn't do the passenger side first, I was just thinking that the resistance was a result of the weight of the car,...and screwing that thing up was just gonna be a pain in the ass.
I was right,..and wrong at the same time....
#1. Screwing that thing up, and having to do so against a loaded spring w/ a stupid pirate hook wrench was a pain in the ass.
#2. Screwing that thing up and galling the threads to the point of lock up was easy.
So,.....Now I'm off for 5 days. I gotta spend hours on what shoulda been a 30 minute fix. I got no way to turn that adjuster any more because now the entire threaded sleeve is spinning (And this is a coil over shock,...not a sleeved kit like on the front).
It's "loaded". There is spring pressure on it. I don't think that I can even get the damn thing OFF the car.
Even If I can,..I gotta stop the threaded sleeve from spinning, and that means (probably) I'm gonna have to try and hold the sleeve at the top w/ a pair of channel locks, or worse,....a pipe wrench. Even then,......The sleeve and that nut are gonna be phcked..... I'll probably have to buy another 170 dollar shock.
Phckin Monster.......:nonono: Why he can't be nice?
Mike, when you do solve it, would you post before and after pics? I'd appreciate the info.
Nice to see your monster out and about, and the description of the driving feel! Some day you'll post some amazing photos & videos.
Reactions: Davedacarpainter
For the benefit of the rest of us that might not have wrestled with such a maniacal device, the problem with the pirate hook wrench is they only work when you have them flipped over correctly. One side works for tightening and the other side works for loosening.
The key is the when you pull on the wrench (you really shouldn't push on it), it pulls the curved open part of hook up against the shaft or tube that has the slot machined in to receive the hook end. Do it the wrong way (and Mike already knew this before he got started) and it doesn't do anything but make you angry...
Reactions: stangboy
Ok....
Well the Monster didn't pitch the fit that I thought he would.
This morning,,, (despite ignoring my wife's snide comments ......Something about having to go down there today, even though I have 5 days off) I went down to deal with the seized strut.
How else could I have the piece of mind that would allow me to be civil to all those around me?
Fortunately, the strut adjusting nut backed off. There was a small little droplet of weld spatter that had stuck itself in the threads of that strut. (I must've had the strut in place while welding the brackets or something)
The little tiny bead had buried itself in the first thread of the adjusting nut. Had I forced that thing farther up,..it would have been a real bad thing,..but fortunately I knew something was wrong.
Nonetheless, I removed the entire strut and cleaned the threads best I could. The nut spins up and down the full length of the strut body, but catches every 2/3rds of a revolution. It doesn't stick hard,..but won't let you turn the damn thing by hand anymore.
Regardless,..I fixed it, and reassembled the strut. I decided to see if I could screw the spring up the additional 3/4" from where it was so I wouldn't have to try and do that laying under the car. I didn't know if I'd be able to get it back in once screwed up,..but I got to thinking about it......( It didn't matter how high I screwed the assembled strut nut,..the shock doesn't get longer,..it just gets stiffer). It fit exactly back in where I removed it from. Only now the spring would not allow the body to compress it any farther than where it was screwed up to. The body was now 3/4" higher.
I put the rear back together,..and drug out all of the previously painted blacked-out trim pieces. I wiped all of that paint off w/ lacquer thinner. This time around,...I primed it first w/ etching primer.
I haven't installed it yet,...I'm gonna let all of that crap dry overnight.
That is provided the wife'll let me go into the garage tomorrow.
Good luck with the wife. Why is it you have 5 days off? Having a stay-cation?
I have accrued 4 days vacation that I have to take before the end of the year. Seemed prudent to take it while #1 is home from Korea, Sunday+ 2 days vacation, + day off, + holiday. And again at the end of the year when it's anniversary time
I don't normally read build posts but this one has been nag'n at me. Gotta be a thriller. I'm going back to the beginning, I've only read this page but it reads like 'how to build a moster while effectively shooting your self in the foot'. And succeeding!
I hope that you've taken a few days off too,....to read through all 226 pages is gonna take a minute...
There really wan't anything to take a pic of,...the strut didn't look damaged. The ride height is noticeable, but you'd have to have the previous pic right next to it to tell.
Ok, for whatever reason I can't remember, I started reading the build on this monster from the first page, go figure, and I'm not done yet, I just had to tell ya'll that fan and the cat thing ( now keep in mind my thoughts are in cartoon vision) was so freak'n hilarious that I had to reread it to that girl that puts up with the 'car thing' that she will never understand, I can barely get through it even the second time without falling off the couch laughing hysterically, the 'girl' just looks at me like'REALLY'
And my cat is sitting in the middle of the living room with that 'if you ever do that to me I'll kill you in your sleep' look.
That was priceless!
Still reading the posts so don't tell how it ends.
