And water meth will cool better than any intercooler, even if I ice down my reservoir. .
From my sense of logic..( which is far from scientific)I would love to see where you got that data.
I will let you know if I can ever get my chit figured out. No intercooler roots blower with WM....
All I can say is this: If it worked that well then all of the boosted guys at the racetrack would be using it....they don't, they use air/water almost exclusively (there are a few guys still stuck on air/air, but not many) I have my own data-logs that show my air/water I/C pulls about 225+* out of the discharge air temp. There is not a water/meth set up that can do that. And I am only making 21iish psi of boost. I will grant you that for the street a water/meth system works, but for max power, meh, not so much.
3. The cooling properties of methanol.
I'm sure that you have guys running straight meth w/o any intercooler at all, unless outlawed by your class. The last attempt at me playing with the big boys was a meth fueled car. It ran so cold the intake was cold to the touch. No intercooler of any kind.
Whatever IAT reduction is gained when 50% of the mixture is straight methanol has got to be significant. All I have to do to maintain that, is keep refilling that reservoir every time I fill the car with gas.
Bmws are A2W on the turbo cars as well, excepting a few older models. They are all turbocharged.I am sure in your application water/meth will do the job quite nicely. Interesting that the OEM's use air/water in all S/C applications and air/air in all turbo applications. Not even an option for water/meth inj.
Yes he can, it would be a simple tie in and a data .ini file addition. But why bother? It's unnecessary information for alot of his effort.Can't you add a 2nd IAT sensor to your mega whatever and data log pre-intercooler air temps? Or does that system not have that capability?
Why Bother? Really? It tells you how efficient the I/C system is. And with that knowledge one can make a more informed decision about where to go from there. Data is knowledge. What you do with it is another thing.Yes he can, it would be a simple tie in and a data .ini file addition. But why bother? It's unnecessary information for alot of his effort.
I suppose if one was so inclined to go that far. It would be far easier to measure the pressure drop across the core. I believe most turbo have a port on the case he could easily plumb a gauge to that and compare to his known value from the ecu.Why Bother? Really? It tells you how efficient the I/C system is. And with that knowledge one can make a more informed decision about where to go from there. Data is knowledge. What you do with it is another thing.
His point was more based on facts... regardless of what the IAT sensor would tell me pre intercooler, it doesn't change the fact that I still have to have the water meth system to go beyond where I currently am at power wise.Why Bother? Really? It tells you how efficient the I/C system is. And with that knowledge one can make a more informed decision about where to go from there. Data is knowledge. What you do with it is another thing.
