that all depends on how much work you want to do.. The ford valve is the easy work around to your damaged board.So,...what do I buy for an IAC valve then?
My whole previous reply is a testimonial to the " id rather work, than pay". What "work" do I have to do? Build an adapter?that all depends on how much work you want to do.. The ford valve is the easy work around to your damaged board.
The GM valve will require you fix the burnt up hard parts on the motherboard... using a ford valve will allow you to use a different output and you could then build an adapter.. I would remote mount the thing.. The ford idle valve [or a simple 2 wire bosch valve used on many cars] is reliable and repeatable.My whole previous reply is a testimonial to the " id rather work, than pay". What "work" do I have to do? Build an adapter?
Nope, not crazy at all. Excepting your advice to have a custom converter made ( read:1000+ dollars) the thought process of bolting the two flex plates together has already crossed my mind. the converter in the 4r70 is a 10" L/U IIRC, i paid a little over 550 for the thing already. I'm not gonna sell that off at 50% if I can make it work. This Saturday will be the start of the process. I'll pull the remnants of the Monster engine, and start trying to fab up some sort of jig so that I can start attempting the marriage between the 2j, and the 4r.lets start with the converter... why cant you have someone make you a converter with the correct size hub? I would start here and then move onto the other items on the list. once this part is figured out a 3/8 steel plate could be drilled to make the adapter. of course you have the flywheel to figure out but if you have a friend with a lathe they could cut the centers out of the jz and SBF flexplates and you could then weld the JZ center into the SBF flexplate and have it balanced...
I know it sounds crazy
And man, I appreciate that.@CarMichael Angelo Send me a drawling and what material. I won't charge you anything really unless its some pricey material lol
Whittle a stick down, attach it with chewed bubble gum, and let’s see some burnouts already.
WOW 750" of crank penetration is a LOT!the japanese converter pilot looked to be maybe maybe in the crank at least 750",
