Therapy today,...leaves me hurting enough to really put a big check mark in the " Do not work on the car today" column.
Before though,...I went down there and wired the 220v circuit to put my welder back in action.
That's done at least.
Tomorrow, I'm gonna do it...I'm gonna get in the mini,........and drive
It doesn't hurt me to sit, and my ability to use my feet and move between the pedals is absolutely business as usual....it's just the walking part that sucks.
I'll go to the metal supermarket, and get the metal I need to seal the gas tank, and build the cover plate for the trunk floor. Herein lies the dilemma, and the reason for editing my thread title tonight.
Maybe, you'll chime in, and offer an opinion.
The tank itself.....I'm gonna weld that plate on top, and make it a permanent solution.
If I use a .040-.060 piece of galvanized steel, it'll cut easily enough, but it'll leave a weld that'll rust, and have all of that white cob-webby residue that comes as a result. But the upside is that it'll be quick, the weld should never see wet gas ( it'll be on top of the tank) and potentially......sealed.
If I do like I originally planned, I can weld a mild steel perimeter frame around the hole, then cover that frame w/ a plate that could be galvanized, or aluminum. Then I could drill and tap through the plate, and screw it down, using grey gasket goop as a sealant.
Right now,..I'm leaning heavily towards just welding the tank permantly,..sticking my hand in the 3.25" hole w/ a small wire brush, and scrubbing that white crap off of the underside of the weld and just letting that dog eat..
Thoughts.?
