Engine 1989 header xpipe cel
See http://www.stangnet.com/mustang-forums/749974-computer-issue.html#post7490537 for Joel5.0’s fix for the computer internal signal ground
There should be codes
He's absolutely right...
Dump codes sticky
Look at the top of the 5.0 Tech forum where the sticky threads are posted. One of them is how to dump the computer codes. Codes may be present even if the CEL (Check Engine Light) isn’t on. You don’t need a code reader or scanner – all you need is a paper clip, or if your lady friend has a hair pin, that will do the job.
I highly suggest that you read it and follow the instructions to dump the codes. http://www.stangnet.com/mustang-forums/threads/how-to-pull-codes-from-eec4.889006/
Reactions: General karthief
Make sure everything is nice and night (no exhaust leak). Also, make sure you didn't leave any of the O2 sensors loose and/or unplugged. Check for codes as mentioned above. Did you drop any of the O2 sensors by accident? Just wondering if there was any possible damage done to the sensors during the exhaust swap.
I appreciate all the help guys thank you one more question… I feel like there's a loss of power but I'm not sure, it feels like when I'm really pushing the pedal it feels like it takes minute for the power to catch up if that makes sense
one more thing sorry..but I also noticed I can push it a little harder, and the car doesnt feel like its struggling, or whatever...instead of switching at let's say 4200rpm, I can switch at 4800 or so....ok, I'm done....so maybe I'm contradicting myself with the loss of power thing?...IDK....and I never made it to the shop to get the codes thanks
thanks man....just feel stupid blowing up with tons of questions...the only issue is the CEL comes on and off...so I'm assuming when I get to my buddies shop with the light on....and turn the car off, when I turn it back on,....the CEL will be off again
thanks guys
ohhh...and one more thing...I'm hearing "whistleing"....when i get up to a certain speed, and while giving it gas, I think....I'll find out for sure the details on my way to work this morning...did it before the CEL...before I chalked it up to the oil dipstick being loose and vibrating something, now I dont think so
thanks
