1992 5.0L mustang MS2 PnP, heads, cam, intake. Idle with AC on?
Got a chance to data log tonight, I notice as I go into boost range of about 5-6lbs and about 3700-4000 RPM it feels as though the engine surges as though Im losing spark(did this before, decreased plug gap and it went away.) Im using all stock ignition, plugs gapped to .038 wondering if I need a stronger coil, re-gap plugs tighter, or if I'm way off in what I'm thinking is the issue. Attached current tune and data log.
Dude you are lean when that starts to happen... look at the log at 5-6 psi you are 13.5ish AFR thats no bueno in boost my friend. In the upper RPM/boost areas you are right on target but you lack fuel where your 'blowout' is occuring. My math says you need to add 8-10% fuel in this area to compensate.
@a91what latest data log from last night, same tune as above. Car feels strong all the way through second gear, usually spins the tires about 3000rpm, shift to 3rd and around 4000RPM under boost I got a drop in RPM and similar in 4th, almost feels like it did when the plugs weren't gapped incorrectly. Im not sure if its a fuel or spark issue, not sure if what Im using is not up to speed with the addition of the S-trim
Trying to work through some minor drivability issues, cold start the car oscillates for a few seconds before stabilizing at a nice idle, also noticing a slight stumble when blipping the throttle, sometimes having to feather the clutch a little to get going. Adjusted some of the Accel/Enrichment settings without much difference so reset them back to what they were.
Its the little things that make a tune great, the changes i made were mostly fuel related it seems like. anytime the car is under load the AFR needs to go rich, beyond this the next issue would be timing in that area... but the timing issue can be harder to pin down so its best to get fuel spot on then tune the IGN table...
as an example if the timing is to far advanced in the low load area during low speed cruise [barely on the throttle] the engine can experience bucking, this is because the engine is making [or trying to make because of high advance] more torque than is needed to maintain speed... = the short version..
Not sure if my previous post went through...apologies if its a double post. Went to the local drag strip for test and tune last night, have a data log and current tune. Looks like fuel got really lean at the top RPM range of each gear and peak boost, adjusted some of cells that were highlighted in VE analyze but didn't get a chance to run again. Hopefully get a chance to do play some more next week.
