would it work or will it throw the A/F ratio all off ???? since the stock cobra opening is a 70mm . would this work to get more airflow ???
93tealstang said:Don't do it regardless if somebody tells you that their car is running fine with a 93 Cobra MAF. The transfer functions are different which basically means that the meter will send false signals to the computer making the car run out of tune. To run a Cobra meter CORRECTLY, a chip with the correct transfer functions needs to be burned. If you want a larger meter for better air flow, go with a Pro-M 77 or 80. Or go with a SN95 70mm unit. It uses the exact same transfer functions and is much larger than the stock fox unit. I run one and it works great. With MAF's, accuracy is the main thing to worry about. What I've listed will assure you the most accuracy.
2002BLGT said:well I am confused because my intentions were to use the electronics out of the stock one and just use the aluminum 70 mm housing ???? seems like the SN95 would be the same thing or am I off on my thinking of how these things work ????
ss93cobra said:IF YOU USE YOUR TOP ELECTRONIC SENSOR AND THE COBRA MAF HOUSING YOU'LL BE FINE![]()
BEEN THERE, DONE THAT.![]()
right back at ya.
93tealstang said:You sir are clueless. Just because your car "seems" to be running ok doesn't mean it actually is. Take a look at your plugs sometime, I'm sure you'll be able to tell from them that your car is probably leaning out. So aright back at ya.
The electronics on MAF's take air samples and send signals to the computer which fluctuates the A/F ratio. The electronics are calibrated to the meter's transfer function which is basically the way that the air enters the meters' sampling inlet. By take stock electronics and placing them into a 93 Cobra MAF housing, you WILL be sending false signals to your computer becuase of the differences in transfer functions. You may think it's fine now, but in time problems will develop.
