1994 Cobra questions
bombcar
I just bought a 1994 Cobra Convertible.
The code reader shows a 332 - anything in particular I should look for?
What's the recommended replacement for the convertible top? I found a few places online but they have many different options (I don't care about keeping this thing stock).
What tires should I get? It needs new ones on the front and I'm thinking I'll just replace all four.
I'm in Socal, if that affects any of the above.
That's a code for the EGR, part of the emissions system. It's not working properly, so you have the code. It could very well be a vacuum hose cracked or removed, rather than a bad EGR.
Where in SoCal?
The vacuum hoses always end up vulcanizing over time with the heat in the engine bay. Replace all you can, I bet it will cure a few issues. The hose that leads to the EGR is actually green plastic; well, it is from the factory. Yours could have been replaced with standard hose at some point.
Passed the smog; technicians spent half an hour looking for the engine. (I think they couldn't read the timing information or something). All registered! Good to roll!
Now for the stereo to arrive ...
