Never had a whoring thread, so here you guys go
and a few videos
at idle after cams
YouTube - 100 3616
and at the track prior to repaint
YouTube - TRACK.mov
MOD LIST:
Suspension/Handling
MM tubular A-arms (delrin bushings)
Koni shocks and coil overs (front)
MM bumpsteer kit
MM solid steering shaft
MM Torque arm bar
MM Panhard bar
MM adj. rear sway bar
MM adj. lower control arms
03/04 Cobra brakes
MPH 800 shortblock
FRPP IRON BLOCK
FORGED STEEL 8 BOLT CRANKSHAFT
MANLEY H-BEAM RODS W/ARP ROD BOLTS
MANLEY FORGED PISTONS W/COATED SKIRTS
MANLEY .150 WALL WRISTPINS
TOTAL SEAL MOLY RING SET
HIGH PERFORMANCE TRI-METAL BEARINGS
Typhoon intake manifold
75mm throttle body
Comp Cams Stage III cams
Fox Lake stage II heads
T56 with King Cobra clutch
31 spline axles and 3.73's
and a few videos
at idle after cams
YouTube - 100 3616
YouTube - TRACK.mov
MOD LIST:
Suspension/Handling
MM bumpsteer kit
MM Torque arm bar
MM Panhard bar
03/04 Cobra brakes
MPH 800 shortblock
FRPP IRON BLOCK
75mm throttle body
