2003 GT Vert - Rear end noise
OtoStang
Orlando, FL
Just got this ‘03 GT Vert Automatic, 108k miles. The car is making a “rubbing” kinda noise, very noticeable at low speeds <10mph and while turning, not going straight.
Could be the tires, brakes, suspension, differential...?
Turning at low speeds (sharper turns) really exposes differential issues because the rear wheels are traveling at different speeds due to the turn, making your ford traction-LOK differential work. You should check your brakes and tire first because those are easy fixes - they are most likely not your issue because you would notice those issues no matter if you are turning.
The differential clutches wear out with time. Check out the rebuild kits here: https://www.americanmuscle.com/mustang-lsd-9904.html
While you are at it I would upgrade to a finned differential cover.
Reactions: OtoStang
