2010 gt threw a code saying both banks 02 sensors lean conditions . Car dies
Jester4439
South Carolina
My 2010 gt has 45000 miles on her with frpp hot rod cams , frpp injectors , stock manifolds and cats, muffler delete and jlt CAI. It’s a 5 speed manual. Today it was running fine and the cel came on I pooped into oreilly and they scanned it and said both o2 banks were lean condition but it seemed to run fine . I went across the street and fueled up with 93 and about 4 miles down the road the car backfired and started idling funny and hesitating while driving. After a few more
Miles It got worse and the engine died . I pulled onto the side of the road let it sit for a while restarted it and it was still running back but I limped it to a nearby gas station where I disconnected the negative cable for 10 minutes and hooked it back up same symptoms but now it will start and idle terrible but when you press the accelerator it struggles to rev up and shakes . When I’m hear it hasn’t enough power to pull into a parking space. I had to have it towed home . I do not know who did the tune because I bought it from a ford dealership 2 weeks ago 100 miles from home and have used a full tank of gas no problems . The only thing I’ve done before this drive today was clean and oil the air filter on the CAI and delete the mufflers. I put approx 30 miles on it after those 2 things before this issue . Any help would be greatly appreciated. If anyone has had this issue and know of a fix for it please let me know as this is my first mustang as I have always driven mopars. The car ran like a raped ape until today . And I have searched forums until I cannot see anymore hoping to find a solution before posting this question.
Thanks
Jason
  • Sponsors(?)
Jester4439
South Carolina
David young , that was something I was wondering as well but I used a k&n recharge kit which is pretty cut and dry clean , dry, oil and put in car- what would that mess up and how do I fix it. It’s dead in the water right now .
Admin Dude
Jan 4, 1985
28,951
10,932
224
Box behind Walmart
www.stangnet.com
What other codes are spitting out. If that's the only code (unlikely) you have then you've lost a fuel system component or now have a significant unmetered air inlet someplace.
Thread starter Similar threads Forum Replies Date
V Drivetrain That Heck Darn 2010 GT 5-speed shifter 2010 - 2014 Specific Tech 0
C 2010 Stability Control 2005 - 2014 S-197 Mustang -General/Talk- 0
E Driver Door Lock - 2010 Mustang 2005 - 2014 S-197 Mustang -General/Talk- 0
L Just bought 2010 GT with 38k, what should I look out for? 2010 - 2014 Specific Tech 4
J Hazard lights flashing before/after SJB replacement 2005 - 2014 Specific V6 Tech 0
S For Sale Eibach Sway Bars 2005-2010 Suspension Parts 0
D 2010-2014 clutch/brakes pedals needed 2010 - 2014 Specific Tech 0
6 2010 Drivers Door Glass Hits Bottom Hard? 2010 - 2014 Specific Tech 2
Ahnt Just picked up, 2010 GT. Stiff clutch, hard to shift? 2005 - 2014 S-197 Mustang -General/Talk- 6
E 2010 Mustang GT - randon, intermittent, fresh hard starts with rough idle. 2005 - 2014 S-197 Mustang -General/Talk- 0
I 2010 v6 base idle problem 2005 - 2014 S-197 Mustang -General/Talk- 8
RC Sanders How to Determine Track Pack option in VIN for 2010 GT Prem. 2010 - 2014 Specific Tech 2
I Upgrading head unit in 2010 base, double din dash? 2005 - 2014 S-197 Mustang -General/Talk- 5
P 2010 Mustang ignition key 2005 - 2014 S-197 Mustang -General/Talk- 0
A Electrical Turn signal relay 2010 - 2014 Specific Tech 0
L 2010 mustang v6 engine swap. 2005 - 2014 S-197 Mustang -General/Talk- 1
O Zex on my 2010 Roush. 2005 - 2014 S-197 Mustang -General/Talk- 0
M For Sale 2010 gt premium w/track pack ($15,000) S197 Mustangs For Sale (2005-14) 0
B 2010 Base Steering Wheel Swap for Premium - Will Cruise Buttons Work? 2010 - 2014 Specific Tech 0
J For Sale Procharger D1SC system for 2010-2014 Mustang GT or Boss Engine and Power Adder 0
B 2010 v6 porblem 2005 - 2014 Specific V6 Tech 0
P 2010 whippled gt 2005 - 2014 S-197 Mustang -General/Talk- 0
D 2010 Mustang Coupe V6 Fuel smell > 1/4 tank 2005 - 2014 S-197 Mustang -General/Talk- 0
V 2010 vortech supercharger mass air flow sensor showing code p0102 2010 - 2014 Specific Tech 1
G 2010 V-6 steering wheel shimmy 2005 - 2014 S-197 Mustang -General/Talk- 2
S ?'s on auto to manual swap 2010 GT 2005 - 2014 S-197 Mustang -General/Talk- 2
M Multiple codes popped up on my 2010 v6 mustang HELP The Welcome Wagon 1
S 2010 MUSTANG 2010 - 2014 Specific Tech 1
Z Drivetrain 2010 Mustang GT 4.6L - Off/On Stiff Clutch 2010 - 2014 Specific Tech 1
V 2010 GT 5-speed remote shifter 2010 - 2014 Specific Tech 1
B 2010 GT Seat Help 2005 - 2014 S-197 Mustang -General/Talk- 4
0 Engine tick and vibration 2005 - 2014 S-197 Mustang -General/Talk- 4
6 Engine Suggestions please for diagnosing starting issues 2010 V6 2010 - 2014 Specific Tech 2
L 2010 Mustang PROBLEMS! 2010 - 2014 Specific Tech 1
6 Interior and Upholstery Info for removing dash parts without damage 2010 Base V6 2005 - 2014 S-197 Mustang -General/Talk- 2
V Drivetrain 2010 GT 5-speed Shift Knob 2010 - 2014 Specific Tech 1
P 2010 Only 1 Key. Can I make 2 clones 2005 - 2014 S-197 Mustang -General/Talk- 0
J 2010 V6 Rattle 2010 - 2014 Specific Tech 0
W bought 2010 v6 thats been crashed and rebuilt missing parts 2010 - 2014 Specific Tech 0
V SOLD 2010 V6 Premium w/ 5-speed ($3,750) S197 Mustangs For Sale (2005-14) 0
J 2010 Cat back drone - advice 2005 - 2014 S-197 Mustang -General/Talk- 1
N 2010 mustang adding amp n woofers 2005 - 2014 S-197 Mustang -General/Talk- 0
R 2010 GT thumping/shaking up front 2010 - 2014 Specific Tech 0
K 2010 Track pack wheel minimums 2010 - 2014 Specific Tech 0
C PLEASE HELP 2010 GT losing power. 2010 - 2014 Specific Tech 4
ProjectDemon Engine 2010 Gt coyote swap 2010 - 2014 Specific Tech 0
P NEWBIE WITH 2010 ROUSH 540RH The Welcome Wagon 2
F 2010 Mustang GT 2005 - 2014 S-197 Mustang -General/Talk- 0
J 2010 GT Need advice re: PCM i.e. buy new car or try to repair 2010 - 2014 Specific Tech 1
G 2010 Mustang GT factory HID? 2005 - 2014 S-197 Mustang -General/Talk- 3
