Yes, assuming you buy the Pro-M meter designated to work with the 42lb/hr injectors, it will work fine. It's still going to be a little rich in the lower regions and throughout the power band though. No combination of injector or MAF meter will be dead on with the stock computer until a proper baseline has been established via ECU tune.
Troofs with one caveat. With a tune, any Fox compatible injector can be used with any Fox compatible MAF. Mass ir transfer function and injector size are irrelevant where the tune is concerned so long as injector size and maf opening are large enough to support the application.
In other words: I can take a "calibrated" MAF designed for 24s and run any size injector I like with a custom tune.
