289 Heads
  • Thread starter Thread starter FoxGT87
  • Start date Start date Aug 2, 2009
F
FoxGT87
5 Year Member
Aug 1, 2009
1,518
St.pete FL
Aug 2, 2009
  • Aug 2, 2009
i have been seeing people say that they put 289 heads on their 302 block, what does this acomplish. can i keep my top end the same with out changing anything.
out side of that is their any economical heads out there that would be a good upgrade from stock, is a GT40 head my only choice? i know that sitting on my 302 now is iron heads so im assuming they are stock.
faststang90
522
baytown texas
Aug 2, 2009
  • Aug 2, 2009
i never had them on 1 of my motors but this guy i knew said that the 289 heads had a small cc and the comp ratio is raised.
57fairlane
560
Oakwood, GA
Aug 2, 2009
  • Aug 2, 2009
exactly . . . I think the factory chamber is around 54cc on the 289 heads.
The only problem is sealing up the water passages to the intake . . . not hard just make sure you adequately seal it with rtv.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Aug 3, 2009
  • Aug 3, 2009
All they do is raise compression. The early non-Thermactor 289 heads will also disable some of the smog pump system. You would be better off having the E7s worked over or buying GT40s, Roush iron heads, or shopping around for some used aluminum heads.
F
FoxGT87
5 Year Member
Aug 1, 2009
1,518
St.pete FL
Aug 3, 2009
  • Aug 3, 2009
thanks for the info, i am pretty happy running on pump gas right now so i think i will look into some GT40's or some used aluminums as suggested.
Dino Dino Bambino
1,673
90
79
Cyprus
Aug 3, 2009
  • Aug 3, 2009
Unless you can find a good pair of Hi-Po 289 heads for next to nothing, I'd say don't bother. You can find good used GT40 and GT40P heads in ebay for not more than $300. If your budget can stretch to $500 or more, you might get lucky and find a pair of used aluminium heads.
57fairlane
560
Oakwood, GA
Aug 3, 2009
  • Aug 3, 2009
wow . . . need to clean up some here.
289 heads can be ported (hi-po ports/valves are exactly the same) to produce results on par with ported e7s.
I have seen a few 6 second 1/8 mile passes from 289 heads.
F
FoxGT87
5 Year Member
Aug 1, 2009
1,518
St.pete FL
Aug 3, 2009
  • Aug 3, 2009
all of my friends say go aluminum or GT40. if i run across a set of cheap sound 289 heads i might do some tinkering but i will probably end up holding off for a set of aluminum heads.
Engine Felpro 9333 pt1 (with 8psi boost)
  • JD1964
  • Jan 14, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
Qtrhrse23
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
