3.55's or 3.73's on turbo car.
LoboGrandeMalo
24
Fort Bragg
Hey I have a 76mm turbo that doesn't spool at all in 1st gear. I currently have 3.73's in it. If I put 3.55's will this cause the turbo to spool in first? Also will that make me quicker if I'm making more power from 1st?
Thanks guys.
01 Turbo Bullitt 76mm - Heads/Cams/Intake etc. All Forged. 615@15psi
Big turbo == big lag.
Taller gears may help with the lag but at the cost of reduced mechanical advantage. It may be a wash in the end.
A shot of nitrous might help to wake that thing up...
Where is your powerband at and where do you plan on shifting?
Yes, lower numerical gears will help reduce lag and will allow you to achieve a higher mph in the 1/4 before redline. This all however needs to tie into your combo. If you are shifting at 7k RPM and will only be trapping 130mph in the 1/4 mile, you'll be leaving a lot on the table with some 3.27's (the most commonly used turbo gear). If however you plan on shifting at < 6k RPM with similar trap speeds, a 3.27 will likely be a better gear.
There really won't be a 100% right answer here until you get some solid number in the 1/4 mile and a powerband from the dyno.
Either way, if you plan on running down the strip with some sticky tires a 2-step is an absolute MUST on any turbo'd vehicle. There is no need for nitrous when you are able to launch with 8+psi of boost off the line.
