Well, the time has come. After almost a year of strongly disliking my current motor, I've decided to part it out and build something else for my 1993 Thunderbird. I'm going to need a lot of help and advice though. 90% of what I know about engines and setups relates to the 3.8L SC. So, any advice would be much appreciated! I have found searching the Corral a waste of time. One post will say something is the greatest ever and another will say it's the biggest pile of crap ever, so that isn't going to help me out any.
PLAN:
I'm looking to build an EFI 347 Stroker that will still be fairly streetable. My goal is 400rwhp and 400rwtq. I'm looking at running NA on pump gas at 10.4:1 compression. I guess my theory behind this is to run the best possible heads/cam/intake combo to achieve this goal NA. Do you think that this goal is even reasonable?
BLOCK:
I'm strongly leaning towards the FRPP roller block, 2 bolt main, cast crank, SAE 4130 forged rods, Federal Mogul bearings, and hypereutectic pistons. My only concern is if it going to be strong enough. I don't plan on every spraying it or adding a blower. I really want to keep it NA. The next option would be a DSS block, but that's about $500 more. I don't plan on spinning it much past 6,000rpm. Also, windage tray or stud girdle? Advice on the block??
HEADS:
I think I've got my mind made up here. Looking at the Jegs/Kaase aluminum heads. 7/16" stud mounted rockers, 247cc intake runners, 1.375 exhuast ports, 60cc CNC chambers, 2.10"/1.60" stainless valves. The other possibility is the Trick Flow Twisted Wedge heads. They are about $500 less, but from what I've read and heard, not as good of a head. The heads is one place that I went cheap and screwed up on my current motor, so I don't want to make that mistake again. Advice??
Intakes:
I've been looking at the Trick Flow Tack Heat upper and lower intake with a 75mm TB. The rpm range is 1500-6500 which is right were I am looking to be. I've also kinda been looking at the FRPP GT-40 manifolds. They claim to be the best, but who knows? They are another $150, but I am wondering about how streetable they would be? Not really sure between the two??
Cam:
I have nooo clue on the cam. When I was originally looking at the TFS TW heads, I was just going to go with thier matching cam. Now that I will probably go with the Kaase heads, I'm not sure what kind of cam to run. I totally screwed up on the cam choice on my current motor, so I don't want to repeat that mistake. Again, I think something in the 1500-6500 range and will still idle half way decently. Most likely be looking at 1.6 or 1.7 roller rockers. I really have no idea of what cam I'd like to use, so any advice on lift and duration would be much appreciated!
Fuel:
I'm not really sure of the fuel needs on a NA application. I'm running 42# injectors in my SC right now, but I know that SC vs. NA is totally different. Would 42# be too much for this engine? Would 30# work better? Also, adjustable fuel pressure regulator of stock? I'm currently running a Walbro 255FI pump. Do you think that will be able to keep up with a motor like this?
Other:
I'm planning on running all MSD ignition, high flow oil and water pumps, Griffen radiator, and some coated long tube headers with 2.5" high flow cats going back to a dual in, single out 3" resonator, 3" pipe back, and then Y it into a dual 2.5" Dynomax mandrel bent setup. Probably just some FRPP lifters, timing chaing set, intake pipe, etc. Pro-M MAF for sure, most likely thier 75mm unit. March underdrives and such. Anything else I should for sure consider?
Any advice that can be offered would be much appreciated. Thanks!
Thomas
PLAN:
BLOCK:
HEADS:
Intakes:
Cam:
Fuel:
Other:
Thomas
