I would then be concentrating on improving the flow back from the heads if that is the issue. That sounds like it is just time and effort, not much in parts, if any.When we built this Cleveland we did get the oil restriction plugs put in. It also has the oil modification kit installed which routes oil from the block right at the oil pump to the back of the block to force feed oil to the number 4 and 5 main and rod journals. You can see the oil tube crossing the intake in my pictures. That will supposedly significantly help with the inherent oil starvation issue. I’m no expert, that’s just what I’ve learned through research. However, there are some people out there that believe another part of the problem is the oil pump will pump oil into the valve covers faster than the heads allow it to drain back to the oil pump. At high rpm’s this causes oil starvation at the pump. One YouTuber claims he tested this theory and ended up with 3 quarts of the 5 quart capacity in the valve covers during a dyno pull. I don’t know for sure if this is factual, but that’s the information out there right now.
My thought is if that is true, having higher capacity oil pan could help in this situation.
The other question is, how long do you anticipate being at WOT? Outside of a Drag Strip, is there really an opportunity to be at WOT for over 10 seconds straight? A typical oil pump will move between 5-8 gallons a min at max rpm. At 7 Gal a min, you would move 4.66 qrts in 10 seconds.
