Hey motor heads
What gives?? I Just got my dyno results on my 351 W. It is installed in a 69 Bronco so forgive me for that. Here's the run down:
351 bored .030 over, stock stroke, new Hpyer piston, moly rings, Trick flow T/W heads with 2.02/1.6 valves, not ported or anything, cam .530 lift 112 cen. 215 dur. @ 50, Trick flow 5.8 intake with 1" spacer, 70MM throttle body, 73 MM C&L mass air, 24# FMS injectors, FMS harness, A9L computer, long tube headers, 2-1/4inch crush bent dual exhaust with Dyno Max mufflers. I guess that's all you need to know. It maxed out at 175 HP at 4500 RPM and around 250 ft/lbs of torque, the torque peaked around 2k and held steady all the way through which is good. It is running pretty lean probably because of the C&L, I've heard they are famous for that. The tuner suggested going to larger exhaust and maybe a smaller throttle body, and a different mass air, but is this going to make up the 100 HP I seem to be missing? Or is the Bronco drivetrain just sucking up all my power? I have an NP 435 4 speed truck tranny going into a stock Dana 20 Transfer case, into a Ford 9" with Detroit locker and 31 spline axles, turning 33" tires. I though I would have twice this much power? What is up?
Thanks
Thanks
