If you're going to be cruising at 75+mph on the open highway, then I'de go with 4.30's, unless if you plan on stepping it up to a taller tire for the rear in the future to kill the rpm increase just a tad. I know I'm around 2700rpms with 4.30's at 70mph in o/d. Since you have a 5spd, your rpms might be a tad less in 5th gear.jasonh_86 said:I usually drive 75-77 on the highway.. sometimes i get up higher, just to get around 18 wheelers and such, but not much.. i rarely race past 90.. which gears would be best tho?.. 4.10's, 4.30's? or 4.56's? and there is rarely bumper to bumper traffic, well not while i'm out anyways.. i'm usually at home outta school by the time the crappy traffic comes thru town
Dark Knight GT said:If you're going to be cruising at 75+mph on the open highway, then I'de go with 4.30's, unless if you plan on stepping it up to a taller tire for the rear in the future to kill the rpm increase just a tad. I know I'm around 2700rpms with 4.30's at 70mph in o/d. Since you have a 5spd, your rpms might be a tad less in 5th gear.
. As you can see, I would be darn near maed out in the 1/4 right now with 4.10s. If I had to hit 5th (like with 4.30s) my MPH would SUCK.Any idea what you'll redline at with stock gears? Or do I need to go find out?hotmustang331 said:Well its like this, 4th gear with 3.73s is about 115 @ redline...4.10s is about 101 @ 5800...4.30s seems to be around 90MPH....4.56s max @ 85ish in 4th I belive. These are rough estiments.
wtf are you talking about?? i know plenty of people that have trapped in the 110 range on 410s in 4th or higher.hotmustang331 said:Well its like this, 4th gear with 3.73s is about 115 @ redline...4.10s is about 101 @ 5800...4.30s seems to be around 90MPH....4.56s max @ 85ish in 4th I belive. These are rough estiments.
Thats why i chose 3.73s. As you can see, I would be darn near maed out in the 1/4 right now with 4.10s. If I had to hit 5th (like with 4.30s) my MPH would SUCK.
Just get more power
Jackie Chan said:wtf are you talking about?? i know plenty of people that have trapped in the 110 range on 410s in 4th or higher.
. And yesterday when I went to 6050 and showing JUST over 120, i was actually doing 124. Then add on my 26inch tires I was going 126 REALLY. hmm
Perfect gear for when I get the 2.2 KB
. (note, the tire height doesnt effect my speedo vs tach relationship...it was 115 @ 5800 before and after the 26 inch tires...only effect REAL MPH)
Depends on the specs of the tire. Will it be the same size as the stock tire height ? If so, the stock tire height for a 245/45/17 tire is approx. 25.7 in diameter, so it would still be close to the above rpm quotes.jasonh_86 said:that's not too bad at all.. but what about a regular tire on an 18" wheel?
