I actually have all the coolant transfer tubes
I had planned to plumb mine with an fittings and do the cross over mod, with my 25.5 chassis there is no way I could even put heat in the car. Stock water pump actually works very well unless you want to go electric and go Meziere
I actually pull the nipple out of the lifter valley and tap that for a AN hose as well
I had planned to plumb mine with an fittings and do the cross over mod, with my 25.5 chassis there is no way I could even put heat in the car. Stock water pump actually works very well unless you want to go electric and go MeziereI actually pull the nipple out of the lifter valley and tap that for a AN hose as well
