5.0 build
  • Thread starter Thread starter 93lxallmotor
  • Start date Start date Nov 28, 2010
9
93lxallmotor
  • Nov 28, 2010
hello im building a mustang found a stock 5.0 motor trya make it be around 400-450hp just need some others ppl ideas i was gonna do a .30 over gt40 heads gt40 upper n lower intake a comp cam i got wit a 588 lift im just not to sure what parts work well together if people can give me some good ideas on combinations of better flowing stuff
Rick 91GT
Mustang Master
95
99
PA
Nov 28, 2010
  • Nov 28, 2010
If you dont have the top end stuff I would look into the Trick Flow top end set-ups, the price is hard to beat and it will get you an honest 350HP. If you want 400+ I would stroke the motor to 331 or 347 with 10.5:1 compression which will net you your 450.
Really depends on your budget, I would stay away from the GT40 parts though for the power level you want.
9
93lxallmotor
  • Nov 28, 2010
im not on sucha buget im doing it over time im just not sure what combos of ****work well other so your saying trick flow for the upper n lower? n not to get the gt40 heads
9
93lxallmotor
  • Nov 28, 2010
and also someone told me if i go .40 over it would get to hot as a dalily driver?
lxman
279
Avondale, AZ
Nov 29, 2010
  • Nov 29, 2010
Im wanting to do the same thing as you! I am planning on getting the Trick Flow Track Heat package and stroking mine to a 347. I figure that should get me pretty close to my goal of 400 to 450 HP all motor. I am planning on doing mine over a course of time. I want to get all the parts first and the get everything done all at once.
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
keel
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
