5.0 tuning problems need advice
Mike Dawg
18
I recently bought a 91 lx and had to put a motor in it and since then i havent been able to get it runing right ive got good compression . and im gettn spark but only 1,2 6,and 8 exhaust pipes are gettn hot the others are barely warm any suggestions?
its possible cuz the exhaust pipes that are not hot the plugs are wet. Ive tried to drive the car there just isnt ANY power like its running on 5 cylinders . when i first start it cold it runs a bit better but its nothing close to normal. if they are what would be the cause?
You will need to pull the codes for this one.
When the car runs better cold that suggest there is a problem with a sensor used in closed loop control.
Something like O2's, ACT, ECT...
The codes should give you an idea of what to check next.
jason
