Right off the bat, you need to ditch the Powerdyne, if for some reason it could produce that much power, you would blow it up shortly thereafter.
With an S trim, 500rwhp is fairly easy.
The question is how much boost you want to get you there.
IMO, the less boost it takes to get you to your goal, the better/more reliable the car is.
So if you can use the cnc wedges or afr 185's, by all means do so, rpmII intake, custom cam.
42 injectors.
That's pretty much it.
Just remember, the stock block no matter what pistons rod etc will only put up with 500rwhp, and honestly even that's too much. Sounds like you are going to drive this car hard, which i can appreciate, but it may not last long at that number.
450rwhp sounds like a better idea, and you may be able to get close with just a supercharger swap with a pulley. Just remember what i said above, less boost=more reliable, and with gt40p heads (of any sort) the boost level is going to be much higher than with tfs or afrs's.
