Joes95GT said:You're right to an extent. I would use the 70mm as a base size, since that's the size of the opening; start at 70mm and work from there.You left yourself open on this one...
So how do you determine which size throttle body the combination needs? What is the determining factor? Say if I'm using TFS heads, a Performer intake manifold, and a Crower 15512 cam, what size TB?
It is my personal preference to have the lower manifold as the "most" restricting part of the combination, albeit slightly. Since the lower manifold is nothing more than an extension of the intake port on the cylinder heads, the slightest bottleneck in the lower manifold will promote velocity behind the intake valve. When the intake valve is cracked, there is going to be TONS of air getting into those cylinders. That's cylinder fill, and that's the name of the game in these short stroke motors.
Joe
I determine personally by the approximate hp the car will be pushing and what is the primary goal of the car...I do not jump in and say 75mm all the way...I look at what is being run...(street/track/coupe/vert/possible power/etc...)...
Oh and I would say on that combo you listed a 65 or 70mm would be fine...
A 75mm TB or possibly bigger would be great on a blown car because of the FI used to push air into the engine...
You typed: "It is my personal preference"...that is really all it comes down to...but for some on here it is 75mm or the highway...
I guess I'm going to go put on a full 3 inch exhaust...because it will allow me room to grow...
True
way to much
