Joes95GT said:![]()
Joe
I know you wanna say it too, but you know whats gonna happen....
Is it now?greenlantern said:Bigger is not always better. Remmember that what your after here is velocity.
With most camshafts, you will lose an inch or so of vacuum at idle. No big deal. My car lost about 2 inches at idle, and it still runs fine. Unless you are putting a Pro-stock-like cam in the car, you'll be fine and vacuum loss will not be an issue.mace6 said:I'm going to stay with the sn95 for now so I guess the 75mm is my best bet., also, will i need a custom chip? one person told me that on 94-95's that the cam would lower the vaccume pressure and that my computer would have issues with that. thanks for the help!!!!
greenlantern said:IMO 75mm is too big. Bigger is not always better.
everytime i see a throttle body thread i check it and see what u have to say haha, whether its on here or corral.. ur always repping that 75mm tb, what would u suggest for my car?Grn92LX said:75mm. Are you converting to fox style or keeping it sn95 style? Reason I ask is because if your going fox style use an accufab, but if your keeping it sn95 I dont know what brand to recommend since accufab doesn't make TB's for your years. I had an accufab 65mm then switch to an accufab 75mm.
ARed1995GT said:everytime i see a throttle body thread i check it and see what u have to say haha, whether its on here or corral.. ur always repping that 75mm tb, what would u suggest for my car?
Joes95GT said:Lets think about this a little bit...
I contend that velocity is created in the runners of the (long) runner intake manifold. Others contend that throttle bodies regulate velocity. If that was the case, then could you use a 60mm TB on a Vic. Jr. intake manifold on stock heads and it would run OK because the TB is creating the velocity?
Joe
The last thing to remember about choosing a throttlebody is shouldn't be larger than your mass air meter. You want to create a funnel for the air, so the mass air meter and filter should be large and necking down to the throttlebody.
