66 mustang t-5 swap
kevs66stang
right now i have a c4 tranny and i want to do a t-5 swap. i was wondering if there was a way to keep my brake pedal assembly in there and just add a clutch pedal or do i have to buy a brake and clutch pedal assembly. thanks for all replies
You can do that, but you need to cut the brake pedal pad or it will overlap the clutch pedal pad. Also, you will need to fab up something to keep the clutch pedal from pulling back too far. If/when you get the clutch pedal, the top has two arms reaching either back and forward. The one towards the driver when mounted rests on a rubber pad mounted on an "L" shaped bracket then mounted to the hanger. Hope that helps.
