67 Super Snake Project
Roll Bar, Seat Pans & Shock Tower Hole
Installed the roll bar, seat pans and cut a hole for the shock tower conduit.
Roll bar.. (bad picture quality)
Seat pans..
Shock tower conduit for A/C lines, one heater hose and the battery cable.
Got too tired. Will finish it tomorrow.
krash kendall said:
So what are you doing for front suspension? You've left the shock towers installed, but have made them unserviceable. Haven't seen that before. Oh, and your work looks great!
Unique Performance Coilover for the front. The upper shock mount point is very small. Will fit in nice and tight beside the tube. See picture of a finished car.
And thanks, got a lot to do!
:jaw: Good Lord Man!
You are doing everything that I want to do to my 67 Fastback and then some. You are certainly going about it better and faster than I am. I'm in Wichita Falls, so if I'm ever in your area I'd be glad to take a look at her. Great Job!! :nice:
TY. You are more than welcome to come take a look. Leave me an E-Mail.
Brake/Clutch Pedal Backing Plate
I fitted the Brake/Clutch pedal backing plate. Good thing I test fitted the Brake/Clutch assembly. 3 hole were cross threaded. And the backing plate holes did not align correctly. I used a die grinder to enlarge the holes to fit.
Also welded the hydraulic clutch backing plate. No hole in the firewall would align. So I welded up the non used ones, and used the die grinder to add the ones I needed.
Car is lookin great!! Im just happy you didnt let the morons at Unique build the car..I have seen first hand their work quality and its sub par in my opinion. Their old paint jobs used to look like someone did it with a roller.
Unique Performance
I must admit though, they did come up with some good ideas. I have not seen anything from them that I would consider "sub par" :shrug:. Doesn't mean that it isn't so.
However, I THINK that my car has a better builder :D :SNSign:
BTW, TY :nice: :nice:
They do have some good ideas, but I feel their work is terrible. May have gotten better over the last while but I have known people that worked there and seen the stuff first hand and its not great for a $200k car. Id expect a lot more from their end.
I may have missed this info, but what kind of set up are you using for the rear suspension? I was thinking of using the Airbar set up from Air Ride Technologies in my 67. I posted this question on the forum earlier tonight, so far I got one input from xoxbxfx.
I am going to use the coil over suspension from UP. Some people believe that it causes a binding situation. Not sure what "binding" means, but I think it is better than the leaf spring/air bag setup for MY needs.
However, air bag is not at all bad. Hope I didn't misunderstand your question. Just Googled the Airbag system from Air Ride and it looks nice. May be better than what I am contemplating!
