Hey,
I'm having a stalling issue with my 69 Mustang, it has a 351 4V Windsor, Auto 3spd.
Car used to only stall after full throttle jabs. Now it will stall periodically just during operation. Stall will happen when moving or when stopped, just feels like a loss of power.
Car will start up again after a round of cranking and pinning the pedal. I believe it is flooded, as I don't pump the pedal, but just pin it once and keep cranking.
So far, I have:
Changed the coil
New plug wires
New plugs
New cap
New rotor
New fuel filter (but WOT is better than ever, so....?)
Took the top off the carb, everything inside is clean as clean.
Air filter is in good shape
I believe the breather on the driver's side valve cover is flowing properly....is there anyway to confirm that?
I could sure use some ideas, really stumped.
Thank you,
Nick
So far, I have:
Changed the coil
New plug wires
New plugs
New cap
New rotor
Thank you,
Nick
