What're y'all doing?
I have commented several times over there mostly because I had no clue I was "over there".I'm making a "Cliff Notes" version of this big as*ed thread. I'm only including pictures of actual progress. So if you want to do a quick catch up, here's the link. https://www.stangnet.com/mustang-forums/threads/83-t-top-coupe-cliff-notes-edition.900362/
Just so you know, the first twenty-five pages of this thread fit into barely over two there.
Don't comment over there, I'll delete your post.
I noticed that as I was going through the thread. I’d keep forgetting about things I had done.I have commented several times over there mostly because I had no clue I was "over there".
Regardless of how consolidated it is Dave,..it still takes hours to read through.
You have done a ton of sht already.
Precisely what I was thinking JR.If you are going to replace the radiator support just wack the center out with that handy dandy sawsall and yank the whole thing.
Jmo
Do you not have an old yoke you can stuff in the tail shaft
Leave the trans lines hooked up or cut the lines and connect them with a rubber hose, but then you knew that already.
Tonight I'll remove the driveshaft, cut out the radiator support and a few other things to get ready to pull it. I'll drop the pan as well and let it drip for a day. I need to drain the tc as well, assuming it has a drain plug.
I need to air up the right rear tire too, i'll need to shift the car around a little to do this.
At least with the radiator support out of the way I won't have to lift too high. The door in the storage unit gives me a low ceiling.
I intend to block the tailshaft with the yoke from the driveshaft. I'll take the driveshaft with me to work tomorrow to remove it from the driveshaft.
Do now! Thank youYou know some part stores have a plug for the tail shaft for like $6
You do know that even if you plug the TS with that plug, and pull that transmission " full" of old, disgusting, smelly, brownish transmission fluid, it is still gonna leak past it?Do now! Thank you
